- Thread starter
- #61
Received wrong plate: 2mm, got money refund but item not available so asked Toyota dealer, waiting now for part 41361-60010 ( 1.60 mm ) a € 35 a piece! (OEM)
Listening some minimal while waiting
Also ordered from dealer (if hard to find, buy at dealer) the 15131-22010 ; VALVE, OIL ADJUSTING; VALVE, OIL PUMP RELIEF. VALVE,RELIEF
Spring seems to be reused fine.
If it sticks: very high oil pressure, exploding oil filter, leaking oil trough seal to clutch.
Still can not figure out if valve near oil filter is the same!
This is the valve next to the oilpan:
H 2H 12HT Engine
part 15134-20010 gasket oil pump release
part 15131-22010 ; VALVE, OIL ADJUSTING; VALVE, OIL PUMP RELIEF. VALVE,RELIEF
Oil Pump Relief Valve and Spring to suit Toyota Landcruiser H 3.6L, 2H 4.0L and 12HT 4.0L 6 Cyl diesel engines.
Suit HJ45 with H engine 1/1975-6/1980, HJ47 HJ60 HJ75 with 2H engine 8/1980-12/1989 and HJ61 with 12HT engine 10/1985-12/1989.
Assemblies ENGINE OIL COOLER (4M; MX3#); ENGINE OIL PUMP (1600CC; TE3#,51); ENGINE OIL PUMP (1800CC; COROLLA (TE72)); ENGINE OIL PUMP (2200CC; CELICA (RA42)); ENGINE OIL PUMP (2200CC; CORONA (RT119); ATM,3-SPEED COLUMN SHIFT; 2200CC; CORONA (RT105); ATM,3-SPEED FLOOR SHIFT; 4D); ENGINE OIL PUMP (2200CC; CORONA (RT134)); ENGINE OIL PUMP (2200CC; TRUCK, PICKUP (RN32),42); ENGINE OIL PUMP (2H; LAND CRUISER (HJ60))
Seals are easily mixed (i searched a lot for this part that has a few versions and is used in every toyota model)
H 2H 12HT Engine
(nokia windows phone vacum, replace for android this week)
), should launch to orbit to work in non-gravity.
