Wait, you didn't give yourself the KrazyFJ handle for being moderate or conservative. Disregard everything I've said before.
You need a V-8 with lots of torque. I'm thinking 383 Chevy. Back it up with an SM420 or SM465 and an NP205 with a 3.0 gears. That will give you a crawl ratio about 90:1 and the muscle to spin the wheels inside your tires when you want to wail in the mud. MAYBE.
A stock FJ40 crawl ratio is about 30:1, or 45:1 with the Aussie tranny and a 3 speed case. The drive train was designed for a 28-29" tire. If you go from 29" tire to a 37" tire your effective crawl ratio drops dramatically.
IE. If it is 30:1 with the 29's than it is effectively 23:1 with 37's. 29/37 X 30 = 23.5. If you have the 45:1 it is effectively 35.3, 29/37 X 45. You have to go with much deeper axle, tranny or t-case gears to get that crawl ratio back to where the stock engine would be happy. You have to go to at least 4.88's to get even close on the original ratios.
There are very few V-8 options, if any, that make 200 foot pounds of torque from 1000-2500 RPM where we do most of our wheeling. I think your issues are more related to gearing than a lack of torque. The F & 2F engines make torque at the sacrifice of HP and RPM's. Like a tractor.. Have you checked to be sure your compression is good in all 6 cylinders?
I think that the stock 6 with proper gearing would be OK unless you are driving it on road. If that's the plan, you will definitely need a bigger motor.
