The Daily Chat Thread
Great video! But did you wheel?
`Larry I have a 1974 F motor, it doesn't have the little bit more that I need to run the 37's, I have issues on steep uphills, mainly ledges that are abundant in my area, if I can stay steady and constant on the throttle I am usually good, but if I bounce or don't make it up it usually stalls and is very hard to start making it dangerous at times, I'm looking to make the truck a little better all around, the carb is just too finicky,
Rick ill check out the 60's in Maine and let you know, thanks
Jason do you still have the bell housing?
having the F means an even bigger increase in power with the 3FE. I'm wanting to build a trail 40 and want it FI for those reasons. Unless you are mud bogging I don't see the need for a v8.
Putting a V8 in mine, only reason is for road travel. The old F engine doesn't have enough power to push
36" tires down the road. Never had any trouble off road and the stock carb does work pretty well when you are on an angle.
What road travel? Every year you report your accumulated mileage to be around 6. LOL
having had both a 3fe and a v8 for a trail rig i would go with a 3fe when that engine was right it was right. if the 3fe yahoo list still exists there is an amazing collection of performance mods in the sites file section. the 3fe gets a bad name due tot he horrible A440f auto tranny. but some of the main things that add hp without getting to in tot he engine were boring the throttle body out 3mm getting cleaned injectors headers to 2.225 catted pipes to a Y to 2.5 back was the general consensousalso something with the AFM. but if you do use a 3fe check out the 3feyahoo groups site
I did some searching and here are the numbers that I found for the different engines
F - 209 FT Lbs / 125 HP
2F - 200 FT Lbs / 135 HP
3FE - 220 Ft Lbs / 155 HP
Now this is obviously a new engine with good fueling. From experience an injector cleaning on the 3FE brings everything back and costs about 200.00. On the others with carbs I don't know.
I've been wanting to build a 3FE trail rig for a while. There is a guy in the 80 section that made a stand alone ECU for this engine, It plugged right into the stock harness. This allowed you to ditch the VAF sensor and go with a MAP sensor and have complete tuning capabilities. This also opens the door for a power adder like a Super Charger.
Tom, Buy yourself a Jim Chenowyth carb if you can't set one up yourself and then change the gearing. 37's are a quite a bit overboard for a 40 with 4:10's. Just remember that the lower gears add stress to the axles and birfields. You've been down that road before with your FJC, so you know what I mean.
Someone mentioned that the FJ62 not having power was due to the auto. The real problem is the shift points. I found that if I shifted the auto manually to hold the lower gear before up shifting, it works fine. It is quicker than a 40 for sure despite the extra 1000 pounds. The shift points are very low on the FJ62, probably to improve MPG back in the day. However, they can be adjusted, so don't discount keeping the automatic.
After denting up my FJC, the wife thinks she should have her own rig. She wants something somewhat smallish with an automatic. I'm trying to avoid the H**P's. A Tracker may be in the future. I'm still looking for a Toy solution without bobbing the 80.
V8 4skinna?
Tom, Do you have a hand throttle?
