- Thread starter
- #21
ill reuse this one, it's not corroded inside at all. just need new screws and a seal when i pin it back together.careful with that sender they are hard to find
I don't have a charcoal canister. If it wasn't so cold out, I'd go out an check where the lines go....or went. Is it worth getting a charcoal canister or just a vented cap if it's not there currently?You can get new screws for the fuel level sender from Toyota.
The lines and plastic piece are the vapor separator. It keeps liquid gas from getting in your charcoal canister.
"De-Smog" means different things to different people, but you absolutely want a functional vapor recovery system, unless you want your Pig to smell like raw gasoline vapor all the time...
