Ford The Brentstangs.....68 Mustang build
Happy 4th of July 🇺🇲
Transmission is out on my modified floor jack. Time to find the leak.
Thanks. I am enjoying my leisurely Mustang leak investigation and hopeful fix. The rear main appears to be installed backwards and possibly some drivers side valve cover seepage. I'll get some new seals tomorrow and keep on trucking.....I mean reassembling..... :grinpimp:
Just need to reinstall the driveshaft, exhaust, and fill the transmission. First through, I need to fix this dog crap weld. I used a different exhaust shop and I regret this......welds by a shop should not look like this.
Here's a shot of my make shift transmission jack. I bolted this plywood to the jack and then ratchet strapped the trans to it. Work better then expected.
All finished and waiting to see if there's any leaks. Haven't run it yet. Gonna redo the exhaust hangers by the mufflers tomorrow morning.
Still need that power steering line and wire the trigger for the AC with the Sniper.......a few other small items as well.
Monsoon season is in effect here in AZ.......meaning humidity is way higher than normal. Makes the garage like a sauna.
Anyways, I added those exhaust hangers I was supposed to do last Sunday. Now the mufflers are properly supported and level.
Gonna hit it in the morning with hopes of finishing up a bunch of loose ends.
Thanks to the internet and boo hiss on the instructions. I found the fix to getting the gauge cluster to fit. You need to drill 2 holes in the dash structure for the studs on the back of the cluster. After that I got it in and screwed down.
Still need to tidy up some under dash wires and run and mount the ac duct.
