Ford The Brentstangs.....68 Mustang build
Everything is mocked up and the belt seems good. Need to pull it all back apart and add gaskets and sealer. Then do final torque.
I got the shifter base adjusted so it starts in park again. Evidently when I secured the shifter base it was not letting the shifter arm go far enough forward to engage the neutral safety switch.
I also began troubleshooting the lack of brake lights and turn signals. I may have a few leads in the turn signal pigtail mismatched......not sure yet. I am getting power at the brake light switch. I can jumper the leads and light the brake lights. Might need a new switch or to adjust it?
I found there are 2 different brake light switches depending on power or manual. I converted this to power disc and rear drums. I not only had the wrong switch, but it was broken as well.
Picked up new versions of both this morning. There's a clear difference. The old incorrect switch was tough to remove, so hopefully the new one installs easier and functions properly.
Got the spare tire today. Sure makes the trunk look small. I had the original spare tire hold down hook. I made a spacer and screw on handle to hold it in place.
I also got the drivers door all together. New door panel, arm rests and more weather strip.
Thanks to friends Steve and Steve, stuff got done this morning. Steve did a great job and installed the stereo. Then other Steve and I got the scoop mounted on the hood. Still need to finish that up.....the hard part is done.
During the stereo install, we discovered a dirty fuse holder causing intermittent power issues. Once fixed, the turn signals now function. The sequential turn signals are now working. WIN
All electrical circuits seem to be functioning as intended. Still need to button up the gauge cluster. There's 2 buttons to trigger gauge read out stuff. They need a home. I will make a small piece that will bolt in next to the column and house these buttons. They need to be easy to use from the drivers seat.
Also need to run the ac vent hose and mount the vent for it. Funny how small this car seems now......lol
Unfortunately I forgot to take pictures.....but today went really well. Betty was more than happy with her new 1968 Mustang. My friend, Brent.....that past , was the reason I did this build. His daughters were also here to see the car.
Everybody was really happy with the car.....which was the pay off for me. Great day.
