Ford The Brentstangs.....68 Mustang build
Started working on rewiring the tail lights, brake lights, and turn signals. Converting the turn signals to do the cool sequential flashing. So far I have tail lights lighting up but nothing else. I have to rewire these 1964 Thunderbird tail light housings as per the kit. Also need to get the reverse lights to work.
I resealed the leaking oil pressure sender. Tightened up the sway bar links. Then cleaned up the oily mess around the bell housing and installed a diaper. This way, until I fix that leak, I can possibly take it for a test drive.
I then took it off the jack stands, torqued the wheels and installed the hubcaps. This is the first time in a long time it is sitting on the ground. It's pretty low and looking really good.
I got a 3 day weekend, so more progress soon.
Just an fyi....the passenger door was not closed all the way in the pix
The rest of the alternator upgrade parts have landed. I picked up the replacement water pump which is definitely different that what is on the engine currently. There is a March serpentine belt set up on here that utilizes certain bosses for locating the various accessory mounts. At this point, I am gonna need to call March and figure this out.
Swapped in the new voltage regulator and began to look into what needs to be rewired. Since the new alternator is like 3 times stronger, there's a new battery lead with fusible link.
As for the water pump, until I get everything apart. It is hard to tell if the new one will work or not.
Upon some stare and compare with a mix of internet research.....water pump was definitely incorrect. New one will work with minor adjustments to the accessory drive. That's for Sunday......I am off wheeling tomorrow
