The biggest problems have the smallest solutions!
Sabinal, TX
Website
www.brushyhill.com
I've been on here, for the past 7-8 months asking...No, PLEADING for help with my '75 FJ40- it's been suffering from an intermittent 'bucking & jerking' problem. I've gotten ALL kinds of great help and suggestions from an endless array of IH8MUD members, but none of it ever solved the problem; although, there have been times when I followed a suggestion and the problem SEEMED to be fixed. In the end, though, the problem always reappeared. By now I've replaced the carb with a brand new rebuilt Toyota carb specially tuned for my FJ and then toyed with the settings ad-nauseum, installed a D.U.I. dizzy and played with the timing until I'm sick of that strobe light, replaced the gas tank and several fuel lines, changed the fuel filter I don't know how many times, installed "Livewire" plug wires and tried and an array of high-dollar spark plugs at a variety of different gap settings, we'd checked, double-checked, replaced and reconfigured the vacuum lines over and over and finally replaced the fuel pump for lack of any other ideas. I even had a valve job done. Not a cheap process, but I'm glad the old girl has all these new parts; BUT, the problem was still there! I can't, or don't want to, think about the number of hours my best friend and I have spent messing with the old girl; but sufficed to say, it was about 5 minutes less than ABSOLUTELY TOO MUCH! This was the most frustrating part- to do absolutely everything that you can think of, and everything anyone else can think of, and NEVER seem to get anywhere - except a lot closer to the poor house! To make matters worse: My FJ40 lives in a small, one traffic light town at my buddy's ranch (an awesome 13,000 acre playground in S. Texas) which is 2.5 hours from where I live and work and at least an hour from the nearest decent parts store; so EVERYTHING we do, or want to do, involves ordering parts and requires me taking time to drive there and back.
It had gotten to the point where I was so frustrated that I had decided to take her to a repair shop; and if THEY couldn't fix the problem I was considering giving up. We were sitting in my buddies house trying to figure out when we'd have time to load my FJ onto one of the trailers and make the drive to the mechanics shop when my buddy started pondering what in the heck the problem was- for the 1,000,000th time.
We KNEW there was some problem with the fuel delivery system - we could see in the little window on the carb that the fuel level would drop under load and then take forever to refill. But with a new gas tank, new lines, new fuel filter and new fuel pump (that day) what could it be? As i said earlier, we'd replaced the carb with a newly rebuilt OEM carb only a couple of months earlier; so how could there be something wrong with it?
Then, as if the proverbial lightbulb went off in his head, my best friend said, "Let's look at the intake connection on the crab!" I replied, "How could that be a problem? We've already replaced or blown clear everything from the gas tank to the carb and we KNOW it's getting the gas because it'll run for a bit before the gas level runs down and it starts getting starved for gas and jerking and bucking! I'm sick of this- let's just pay someone to figure it out so we can go fishing and have some fun, for a change!"
Luckily, he convinced me to check this ONE last thing before loading it up onto a trailer. I pulled the intake fitting out of the carb and looked at the tiny hole the gas goes through to get into the carb. I could see what looked like a little pin in there- almost like a oneway valve- but why would the intake fitting have a one-way valve and, besides, it would be facing the wrong way. I put it up to my mouth and tried to blow through the fitting and I looked like Dizzy Gillespie blwing a horn trying to getr air through that fitting! I took a safety pin and poked at what had looked like a pin and out fell a little tiny piece of metal smaller about the size of a grain of sand. I tried blowing through the fitting again and VIOLA! It worked!
I'd been here before, though- fixed something that we, or someone from IH8MUD, were SURE was the problem and...NOPE, that wasn't it. So, I was still pretty apprehensive about it fixing the problem; but I put it back into the carb and reconnected the gas line and started the motor. Everything seemed to be running fine, but the question was- would it KEEP running EVEN when we really got on to the gas pedal and asked it to suck some gas. I took off down the driveway and everything was fine so I turned out onto the road and headed towards the nearest pasture gate a couple of miles a way- ever giving it more gas. She drove like a dream! With every tenth of a mile further she went, without bucking or jerking or loosing power I got more confident and the grin on my face got bigger and wider! I can't explain the feeling of relief, joy & satisfaction I had the rest of the day (and really ever since) to anyone else- except y'all! No one else can understand but I think some of y'all will!
It just goes to show what a tiny piece of dirt can do and how the simplest of solutions is so often the best! We'd spent so many days, weeks and months struggling over this problem (whenever I could get away to the ranch) and all it needed was a little poke and a puff of air; and now my cruiser is one of the best running vehicles I've ever owned- and one of the coolest trucks in Uvalde county!
I want to thank EVERYONE here at IH8MUD that helped me! I've learned SO much since I first joined this forum and even though I still have an enormous amount to learn, I know I have a resource and friends I can count on to get me past any problem I may have with my cruiser! The brand new 'Newbies' that just found IH8MUD have no idea how lucky they are- but, like me, they'll realize it pretty quickly. Thank Y'all SO MUCH!
Nick Anderson
Austin, TX
Hi All:
Nick, all I can say is :beer::beer::beer::beer::beer:
Congrats on getting your 'Cruiser back! And, buy your buddy a good dinner! He is worth keeping around! :D
Enjoy the rig!
Alan
Bring it to Katemcy next year for the Lone Star Cruiser Round Up so we can see her run!
Later,
Congrats! It always feels great to fix that problem that has been nagging you. Especially one that has been nagging for so long. Good job!
:cheers:
I hope you kept that metal shaving and have it framed on the wall...probrably the most expensive shaving out there! ;)
Glad you got her running and I can attest to the big grin you talk about! IT'S A GREAT FEELING. Good story....
:cheers:!
I'm glad it appears to be fixed once again.
But the fitting w/ the tiny hole is the return banjo. Yes, it has a rubber check valve /pressure regulator built into it. It appears to be facing the wrong way, as you observed, because it is the fuel return, not the inlet. It may have been plugged w/ a piece of dirt (common). but that doesn't cause the carb to run out of fuel.
You might want to remove the fuel inlet fitting and look back into the carb at the inlet screen, to see if it is coated w/ poo. That could cause the running out of fuel under load symptom.
That's great. Back when I picked up my 79 I had an intermittent problem where the truck would randomly sputter and die out entirely. But every time by the time I got back to the truck it would fire up after cranking the starter for a while. Sometimes it would make it home, sometimes it wouldn't. I replaced the carb, fuel pump, fuel filters, coil, points, cap rotor, wires, and plugs. It ran much better, but would still randomly quit on me. After a few weeks a coworker suggested it had crap in the gas tank. So I drained it and found several dead bug carcasses. They were randomly getting sucked into the pickup tube and starving the engine for fuel. Not problems to report since, and it's been 5-6 years.
Hey texan,
This is the first time I heard of your problem, and it seems like you've got it fixed, but are you sure the intake and return lines aren't mixed up? I don't think the intake should have a restriction in the line like that, but the return line probably does. I had the exact same problem you were talking about, fuel dropping in the window, bucking and stalling, and I found out the two lines were switched and it wasn't delivering enough fuel at high speeds. I switched and the problem went away. Thanks to the people on this board.
https://forum.ih8mud.com/showthread.php?t=74406
Those land cruiser crabs are a bitch! :) you might want to see your doctor!
Congrats on finding the solution. As I have learned on my FJ40, whatever you "know" something can't be the problem, that is the first thing you would check. You should have seen me trying to fix everything when my timing was off 180deg.
Now that it runs well, enjoy :beer:
Jim-
Thanks for all your help and for this little tip!
What was happening was: that the inlet was ALL BUT COMPLETELY clogged by that little piece of crud so, when it was at an idle, it could get enough fuel and it would fill up the bowl and keep it full. BUT, when I would drive, it'd drive fine until it had used up all of the fuel in the bowl and then start bucking and jerking and lose power because the carb was essentially out of fuel and couldn't suck enough gas to do anything more than idle. If you let it sit and idle, at that point, for a minute or two, it'd re-fill the bowl and you could take off again; until you'd run through the gas that was in the bowl.
I will take a look at that inlet screen the next time I'm down on the ranch, though- i didn't even know there WAS an, "inlet screen!" See, I never fail to learn stuff on here! LOL! But it's driving like a dream right now- my buddy gets to drive it a lot more than I do and he says it's now one of the most dependable vehicles on the ranch! Thanks, in large part, to all the help I've received here!
Thanks again y'all!
Nick
