I can finally put a bow on this project! I'm so stoked with how it all turned out. Super simple, effective and integrated.
To sum it all up...
I'm using an Iceco JP30 30L fridge. It's not available any longer but I believe Set Power offers an identical version for less $$$.
It's all strapped down with
Iceco straps. I could have probably made something for cheaper but it was exactly what I needed so an easy buy.
The
fridge power cable is also Iceco. I wasn't trying to keep it all in the Iceco family, it just worked out that way.
It's powered by a
Bluetti 100 V2 power station. Just like the fridge I chose it because it was the biggest I could find that would fit in the available space.
I wasn't planning on getting a DC/DC charger right away but
Bluetti released their
Charger 2 a month ago and I couldn't pass it up. It's a powerful piece of equipment for the price.
Fridge makes a perfect center armrest.
Seen here is the sheathed 6 awg cable from the battery coming out from between the f/r carpet and up to the dc/dc charger. The other 2 cables go back and feed the power station. It's all
Bluetti stuff that came with the Charger 2. The 90 degree AC splitter is for ease of AC power access. The drawers are very close. The AC inverter uses a lot of power so I will avoid using AC as much as possible. The rear fridge straps go through the handle on the power station, securing both. The DC charger is sticky velcroed to the power station.
Bluetti advises to mount them vertically. They also don't guarantee it over 6,600' elevation. I live at 7k. Whatever. I'll make sure nothing blocks the cooling fan.
The fridge power cable is a bit long. I keep a multi USB cord plugged in the back to charge all the things. Another strap through the handle on this side.
Up front a strap on each side go down to a D ring on the former center seat mount. The whole system feels very secure. It's also very easy to remove if need be. Since it's in the center of the vehicle it won't see nearly the same forces as it would if it was mounted in a rear corner.
You may have noticed the power station controls are difficult to reach. That's no problem as it and the charger, as well as the fridge are controlled by apps.
The power station stuff was new territory for me. It's been fun learning how it all works. I plan on adding interior/camp lighting at some point. And if needed I can easily augment the power system with solar by plugging directly into the Charger 2.
And now, for me, this is the best part-
Old 60% seat = 86lbs
Yeti 20L cooler + 5lbs ice = 21lbs
Total = 107lbs
New seat = 39lbs
Fridge = 35lbs
Power Station = 25lbs
Charger = 8lbs
Total = 107lbs
