The 80 - 40 connection
blunt
More ambition than motivation
Downast Maine
So I towed my 73 FJ40 project home via a tow bar behind my 94 FZJ80 this weekend. I thought the 80 towed very well and was glad that I made my $50 purchase for the tow bar. I towed it about 20 miles and kept the speed down below 50mph. Now I have another winter project!
Has anyone else tried towing with a tow bar behind their 80? Thoughts of how it handled? Would you prefer a different setup behind you (vehicle on trailer or car dolly)?
Thanks, I get that a lot...there IS a space in there. It is only my first initial and then my last name.
I tried flat towing my old 40 with my 80 once. We had a small group of us driving from Utah to California to run the Rubicon and without a trailer I had originally planned to just drive the 40, but thought otherwise. I modified my front bumper and added attachment points for the tow bar and picked up a set of magnetic towing lights. These pics are from when I hooked it all up for a test run to make sure all would work well.
I towed it about 15 miles on the highway to a friends shop. I lost track of how many times I thought I was going to die along the drive. It turned into a serious whiteknuckle test run.
Here is where I think I had my problems...... At the time my 80 was set up with OME medium spings, 1.5" spring spacers, and RS9000 shocks with 35's. As you can see from the pics, the tow bar was nice and flat (which is what you'd want) and I had good caster on the 40. But I experienced some serious wobbles above 50 mph that nearly caused me to lose control of the 80 as the shaking would increase in intensity as it shifted from side to side until I slowed down. Obviously it wasn't going to work for my 10+ hours to California. I am fairly certain that my biggest problem was the height of my 80 combined with the soft springs that couldn't handle the load.
Since then I've changed to J springs but still wouldn't try flat towing again. I would cautiously try it again with OME comp springs or maybe Slee springs that have a stiffer spring rate. For short distances and lower speeds I think flat towing is ok, but I would only do it as a last resort on the highway with an 80. I had flat towed my 40 behind my bro-in-laws Tundra prior to this with zero ill effects so I know it can be done.
Nice looking rigs! I flipped my tow hitch up (4" rise/5 1/2" drop) so that the tow bar was horizontal also. I would agree that this is not something that I would do on the highway at higher speeds, and would probably want to have shocks hooked up on the front of the 40 next time also to help keep things in line. Overall things went well and I didn't have any thoughts that I was going to die.:clap:
I have OME heavies and found that they kept the wobble to a minimum. I had the most weight transfer issues when I was going around 90* corners (even from a stop) as I was turning onto other roads. Giving the vehicle a little more gas (not excessive) seemed to squat it down and make it track where I wanted it to.:steer:
I used to flat tow my jeep and my biggest concern was the stop ability. Seemed that without having brakes on the towed vehicle, it wanted to push the tow vehicle. Not a big deal when you had time to prepare for a stop, but sometimes stoplights sneak up on you.
It wasn't the most enjoyable time I"ve had towing a vehicle but it worked. A tow dolley would have probably been much better, but it's all I had at the time. We had to hook it on top of the frame rather than the front bumper as it was not strong enough.
Stopping took more effort and emergency manuevers wouldn't have been good. I'd do it in a pinch again, but not for something all the time.
My friend flat tow's his 40 all over behind his camper...so i dunno?
I'm curious as to why some think they need stiffer springs to flat tow a vehicle. When you flat tow, there isn't any weight added to the tow vehicle. More weight in the rear of the vehicle is the key here, which is flat towing with a pick up is so dangerous. The towed vehicle can leverage the rear end of the tow vehicle which is what some of you seem to have experienced. Throw a few hundred pounds more weight in the rear of your 80, and you'll have a more pleasurable tow. Of course a dolly or trailer is probably a better way to go.
I did think about adding some weight in the back of my 80 before towing it but thought I would try it first the way it normally sits. I think the stiffer springs would play a role in keeping the rear from moving around as much. Even though there is not much/any tongue weight flat towing, the pushing and pulling from the vehicle behind you still has an effect on rear forces.
That does look like quite the project. :grinpimp:
I think in two years i'll be at the point where i'll be looking for the same thing.
That's exactly the point. Even with a trailer you can get bumps in the road or even wind that causes whatever is being towed to wobble or sway. Those forces are transferred to the tow vehicle. With soft spring rates those forces will cause more body roll than you would have with stiffer springs. Often times those wobbles turn into a harmonic and intensify and are difficult to get stopped and under control. A stiffer spring would help (some) to minimize this.
Adding weight may help a little but not a whole lot because you still have the same spring rate and unless you are down on the bumpstops there is still room for those soft springs to move and start swaying when it happens.
Yeah, it has been ongoing for many years. I hope I can get it drivable this winter and then worry about body work afterwards. I have almost all the parts to get it going, it's just finding the time to work on it...
