Testing temp sensor guage?
Not the lead that goes to the sender. It's basically the ground wire. The other side of the guage you could put 12v+ to it to test. Generally I just ground the sensor wire to test. And check the guage for 12v supply
exactly , just ground the wire at the temp sender ( engine block sender) and watch it rise .Question ? if you ground the wire and hold it there to long will it fry the dash guage ? just curious
It could definetly. 5 seconds will not hurt you though. And thats all you need to ground look and disconnect.
