Testing suspension travel
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Hello.
I was talking with a dealer yesterday about suspensions and he said I was crazy for using Koni Raid shocks with a 3" lift. "You could even have a tire in the air if you enter a roundabout too fast".
These Koni Raid shocks are advertised for a lift of maximum 2" (they are a bit shorter than the standard OME Nitrocharger).
I never felt lack of suspension travel before but I decide to test it.
As I don't have any roundabout here, I used a lifter.
I agree that the suspension travel is not great, but I think it's enough for non extreme use. What do you think?
This is my helper, in charge of the lifter.
I need some rust treatement here.
I'm no expert, but I don't think you will see that kind lift in a roundabout.........but to be fair i have never driven around a roundabout in the UK:grinpimp:
:lol::lol::lol:
Hawkeye, I am going to take that measurement, what would you call a good value?
By the pictures, does it look like I'm losing some suspension travel for the short shock absorbers?
Maybe a little bit. Honestly....it looks fine to me. :meh:
But what do I know, I'm using standard OME shocks for ~3.5" of lift. :doh:
I was thinking into going with OME L shocks, but I like these ones, they are stronger and twice as thick as OME, so I think It's not worth changinf for just 1" or so of extra travel.
What do you think?
I'm posting the measurements later on.
For comparison, this is a 2" lift (dobinsons springs, lovell shocks) rest is bog std. Looks pretty similar to what you get ?
The only issue onroad would be severely restricted down travel. Doesn't look like a problem in the pics that would cause you to pic up a tire around a curve.
for this test your truck was loaded . ?
It only had the 12000lbs winch that will be installed soon in the boot. About 40kg. Should I expect more travel with a heavy load?
Of course I won't, the dealer just wanted to sell me new shocks and he invented that roundabout story.
I was just being sarcastic when I said that I used a lifter instead of a roundabout.
But he may be right in some way that I'm losing some travel with these shocks. I will post the measurements now.
Dutchie, that looks pretty similar, but I couldn't tell without measurements.
I lifted it again yesterday and tooke mesaurements:
Rear lifted tire with the other three touching the floor (from bottom of the tire to the floor): 71cm 27,9"
Front lifted tire with the other three touching the floor (from bottom of the tire to the floor): 62cm 24.4"
