Testing Diff Locks on a Lift Rack
Auburn
I have read all the write-ups on how to test your diff locks but have never read anything about them being tested on a lift. I'm assuming that if you put your 80 on a rack and put in in low that you should be able to lock the front and rear with all 4 tires off the ground. I'm also assuming that not only will you hear the lockers engage but you will also have all 4 tires rotating (idle speed in Low 1st) at the same speed.
Right?
I'm asking because I have bought an 80 with lockers that will be delivered and I won't be able to see it personally for some time (like late July!). I do want my mechanic to look it over and take care of anything that needs attention before we come home on vacation and want to drive it. It seems to me that asking him to perform the above on one of his lifts would be a very quick way to tell if the lockers need any attention.
Opinions?
(BTW, I have a couple more stupid questions that I'm about to ask! :D)
Thanks!
I wouldn't do it with the engine running. Simply put the t-case in low, the tranny in neutral and move the switch to lock both axles. Then turn the key to the on position and all three actuators should engage and turning any 1 wheel should have all 4 moving in the same direction. It might take a little back and forth at each axle to get them to lock initially.
Thanks Landtank.
At the risk of asking an obviously stupid question.....why not with the engine running? I'm talking about on a professional car lift with tires just off the ground.
Not trying to be difficult...just want to learn! :cheers:
