Ten steps to swap an F motor?
Durango, Crawlorado
Getting into the 63 swap today. I don't know how many of you recall, but my motor developed a very sudden "Fwhump" sound last year, and was blowing back through the carb. A compression test came back with zero on number five, and a visual inspection under the valve cover showed nothing. :confused: :meh:
Another member was kind enough to provide a donor, and I'm starting today.
It seems pretty straight forward, but I was wondering if anybody has done this already, and would be willing to offer any advice? In other words, if you were to break it down on a base level, with the most important things to know:
What are the ten steps (more or less) to swapping an F motor for another F motor?
Thanks :cheers:
:idea:
I forget that the 25 section is like using the regular post; you need to send it out a week ahead of time. :lol:
I may need to answer this thread myself (for the next guy). :cheers:
What year is the donor? If it's the same year.."Installation is the rerverse of removal".
:lol:
60's "F" (as far as I know). It's hard to say what year is in it though, so there's that too. :doh:
I am (as always) amazed at how simple these rigs are to work on. I've always wanted to use that hinge on the front :bounce:
I've decided that trying to do the swap in a day (or so) is not the best way to go about it. It would be a shame not to take the opportunity to clean up the engine bay and spray a coat of paint on the parts (while I can get at them).
So:
Step 1. Slow down and collect supplies. It is best to do it right the first time. ;)
Removal and installation is pretty straight-forward. Some people will advise you to pull the engine, tranny, and transfer case together, although, I've had good luck getting it together without removing everything. It's a matter of personal preference and number of people around to help. It's certainly easier to line things up with a couple of extra guys around to push and pull and offer another set of eyes.
I would replace a few gaskets before installing the new engine. Things like rear main seal, front seal, and oil pan gasket come to mind. It also might be a good time to replace the clutch, have the flywheel turned, etc...
This one I haven't never quite understood how to pull the engine and leave the transmission and transfer case hang in the air. Post 7/80 there is a crossmember supporting the tranny/transfer but before that they hang from the bell housing and the bell housing has the rear motor mounts. Just seems like a lot of work to support the tranny/transfer ridgid enough to wiggle the tranny input shaft thru the clutch and into the pilot bearing. Just curious how you go about this.
Edit: You're right! I was thinking of the later models!
comealong holds the tranny and t case nicely and when lined up right they slide right together.to much extra work removing drive shafts shifter and all the other stuff for me.but that just me.
On hold for now. I'm pulling a 400 out of a motorhome for the 55, so I can take my time and do the swap in the garage.
No need to hurry.
