Temp sensor part number
Mason, Texas
Website
www.irontonforge.com
I've spent considerable amount of time trying to find this part number, and I now concede defeat. lol I'm sure it's here somewhere...
Can someone provide the name or part number for this sensor?
Thank you!
didn't take him long
Which temp sensor is that one?
What is the function of the ECT cut switch?
It will disable your A/C unit if coolant temps hit a certain range (approx. 216-220°F) to prevent it from further adding to the engine heat load. A/C will come back on automatically once temps have cooled back down (approx. 214°F and below).
Anyone know the part number for the connector side on the engine harness that connects to the ETC cut switch?
EDIT: disregard its 10184
So, I'm seeing a copper washer in the photo, but is there a separate P/N for that, or does it come with the sensor? P/N 90430-12005 doesn't seem to be listed as a washer; it's either a Fuel Filter Gasket (toyotapartsdeal) or a Bolt, Union (for Nozzle Leakage Pipe No. 3) (Partsouq)...
And do we need connector pigtails etc. for these, or does the harness clip directly to them? And if the wire/connectors, "pigtails" or whatever can be bought separately to connect these sensors to the harness--does anyone know those P/Ns?
So, I'm seeing a copper washer in the photo, but is there a separate P/N for that, or does it come with the sensor? P/N 90430-12005 is not a washer; it's either a Fuel Filter Gasket (toyotapartsdeal) or a Bolt, Union (for Nozzle Leakage Pipe No. 3) (Partsouq)...
# 90430-12005 is a Copper Crush Washer that provides the seal for that sensor. You might find it variously sold/labeled as a 'gasket/seal'....but its a crush washer plain and simple.
This is apparently the knock sensor wire / pigtail: 82219-35010.
Though toyotapartsdeal says it doesn't fit the 95 LC.
