This is a little long...so sorry.
Background:
I have a '75 FJ40, when I bought it, to the best of my knowledge my Temp Gauge and Fuel Gauge were not working.
To start the process of getting my truck running, I re-wired the entire loom.
I was not overly worried about the Fuel Gauge [just kept a 5gal jerry can handy
], and ran an aftermarket Temp Gauge and sending unit for a while to make sure that I was not going to overheat.
Anyway, I have gotten to the point where I wanted to get the factory Temp Gauge working, so I bought a new factory gauge and tested the sending units to make sure that they were putting out the correct ohms...however, the Temp Gauge still did not seem to be accurate.
While installing the new Temp Gauge I noticed that the problem with the Fuel Gauge was that the wire running across the top of the gauge was broken, or burned in two.
Doing some research as to why my Temp Gauge was not working I read on Mud that the two gauges have a common lead and that if your Fuel Gauge is broken, your Temp Gauge will not work correctly. So I bought and installed a new factory Fuel Gauge.
Still no joy!
Problem:
With everything hooked up when I turn the key (engine not running) my Fuel Gauge remains on Empty and my Temp Gauge slowly drifts towards Hot settling at about 2/3rds of the way.
If I unhook the lead to the fuel sending unit the Temp Gauge will settle back to Cold as it should be...but the Fuel Gauge never moves.
If I ground the lead...the Temp Gauge behaves the same as if it is hooked up.
I have a full tank of gas and the ohms on the sending unit are reading 16, but just to be sure I removed the sending unit from the tank and the Fuel Sending Unit tests true through the range of ohms.
Question:
So...where do I look for this short?
I re-wired the entire loom, and tested before re-installing so I am pretty confident that the short would not be in the wiring itself.
Could the short be in the Gauge Cluster itself?
How do I identify a short in the Gauge Cluster?
Any suggestions?
Thanks!
Background:
Still no joy!
Problem:
Question:
Any suggestions?
Thanks!
