The silver truck is running SKY hysteer with billet arms ( this must have been eight year old now, with no failures). I just ordered the Trail Gear hysteer with lifetime warranty for the 4Runner.
Where is the best place to get a gasket for the rear diff? Mine seems to be leaking. I checked Marlin and they want $52 for a rebuild kit that has a gasket in it but as near as I can tell, I don't need to rebuild the axle......just need to stop ANOTHER leak......and I guess I will need one for the front diff also as I will be installing the ARB soon.
DUH! I was referring to aftermarket. I can always run up to the local 'Yota store.
OK....any body have a diagram of how to connect the fuel lines on the oem tank in a 40? I can figure out that the 3 small tubes go to the fuel evaporator and the larger hose will feed fuel to the engine but 2 questions:
1. There are 2 other tubes coming off the oem tank; one on bottom of the tank and one on the side of the tank that faces the driver. I don't know where those 2 go. Any ideas?
2. What does the fuel evaporator line go to? If I understand correctly, it's a check valve? What is a check valve and where do I get one? If it's not a check valve, then what?
even that it is a Toyota------they change everything every year.soooooo what year ?what reg fed or caf---- ????
check valve = one way valve???
evap line usually goes to the charcoal canister![]()
I have been using some silicone gasket stuff for the third members, easier to remove than a paper type gasket as well.
I'm using a razor and not making any head way. WHAT is the best way to get this very old tint off? Thanks for any help with this .Heard that from more than 1 person. Thanks for helping to confirm that decision.......![]()
Trying to remove the ten year old purple tint off the windows on the back of the 4Runner![]()
Use a hammer and chisel, then install the new window. They have some tint remover at auto stores that sprays on and cover with a trash bag for awhile before peeling it off. Heat gun and razor blades, either way you still have some glue to scrape off.
