TC Linkage Problem
Las Cruces, N.M.
Here is some pics of my linkage. I think it's an alignment issue. i told Poser that there was no pivot point. I was wrong. What do you folks think about a remedy so I can 4 wheel again?
Thanks in advance...
What year is this thing ? Ok i see from your sig it is a 76.
Looks to me like linkage just came off of the one part. That is the part right there that takes it from 4wd to 2 wd. Looks to me you should be able to pop it back on myself.
But i am still trying to figure out the rest of wire/rod type stuff you have in the pic.
Too early in the morning here but again from your sig you have a different eng / tranny combo than i am used to.That being said looks like that wire stuff is what holds it from going to far. ( the lever that is )
Looks to me that the shifter for the front drive is not even close to working with the rod from the front drive acctuator....
attachment.php
Lengthen it, and you should be good to go!
Good luck!
-Steve
The bracket that bolts to the tranny which the shifter pivots on doesn't look stock. What tranny is this? What transfer case? It looks like something is out of alignment as I doubt that anyone would install linkage that can't work.
This linkage setup is apart of the green 76 with a C4/302. The pivot point looks to be bolted to a plate ("L" bracket) that is affixed maybe between the adaptor and the bell.
I'm going to have to clean it up abit and figure this out. As you can see, there is no tc stick plate. The stick just moves any which way.
What looks like wires is really the tranny cable and I think the PO had air shocks or something.
Looks booty fab.
Either something has hit it or someone has been yanking to hard on the shift lefer and bent that mounting point. If it is that easily bent it might be a good time to bend it back and weld some more bracing on it. If it was not easlily bent then you probably have a t-case issue. Though beating on shifter won't help.
This used to work? Poser's seeing what I'm seeing - that shifter 'shoe' isn't far enough back to engage the rod that makes 2wd/4wd happen.
Has that bellcrank been removed and maybe not reinstalled in the working location? I'd look for another place to attach it that's close to the T/C front drive output. Are you saying that the pivot/bracket is bolted onto the bellhousing? That can't be what the original installer had in mind because as is it'll never work.
The whole Transfercase shifter depends on the swivel bolt and it needs to be sturdy, not mounted on some too skinny makeshift bracket for convenience.
Time for a nice new twinstick. Homemade, because of the C4.
