taking out old springs
Pequot Lakes MN
I am taking out my old springs so I can get my frame to the sandblaster... the rear ones fought me the whole time.. I dont even want to tell you how long they took to get off... is there any tricks do doing this easier... I still have to take off the front ones and I am really not looking forward to it..
Thanks!
Mine took a smoke wrench, BFH, PB Blaster, Ape-like strength but they came off. I'm not sure there is an "easy" way to do it.
Oh yeah, and it also took plenty of beer to lubricate all of the curse words.
if you're talking about gettint the shackle pins out of the bushings.
use flame! a propane torch, you can either heat the pins or burn the bushings.
for some reason the bushings will contract and come apart from the pins.
have a fire extingusher (sp:confused: ) handy.
whats cool if when you have the springs out, point the torch into one side of the bushing (while still in the springs) and burn them.
the flame shoots out the other side like a jet engine :D
fun with flame :)
When I did this I worked on it myself and with the FJ being in the rust belt (WI) for the last 27 years, it was brutal. I know your pain. I did find that putting a wedge (block of steel or wood) between one side and the other helped the BFH hammering effect by taking out some of the play when you struck the bolt, spring, sometimes frame, and a body panel on accident or even an occasional thumb. :mad:
Too bad, like you, I find this out when I started on the front. I also soaked with whatever oil, Blaster or kroil...I had for a week on the front. They then came out within 2 hours. The rears were like 5 nights worth of effort.
Good luck. Enlist a friend, pay them with beer.
yea that is where I am at... like 5 hours... I will start soaking the fronts... can not work on them for a few nights so that should give it enough time...
That's one way to do it alright, but nothing beats just burning the bushings out. You can spend hours, hell, days, trying to get them out otherwise. The heat will also help get those rusted nuts loose of course.
Starting Tonite On This Project
I Likey Fire, Cool. You All Gave Some Good Advice. So If You Are Going To Put New Shackles, And Springs On Can You Just Cust Them Off.
yup,
but fire is funner :D
More funnerer!
What are they teaching in school these days. :rolleyes:
Living in the desert has advantages. All it took was a drift pin and a BFH to get my shackel pins out.
