tailgate
Longmont, CO
Would a tailgate from an early cruiser fit in the space of my 78?
I am looking to do somthing similar to this, but I dont know if I want to weld the bottom remains of the ambulance doors together or not.
So in making the tail gate and doors. I could cut the 2 doors down so they are flush with the tub. Then cut the sill to the same lenghth and weld that on top of the now tailgate. Then I would need some scrap doors to make the bottoms of the new top ambulance doors? Does this sound right?
I would think that you would have to chop the bottom 2 inches off the doors and relocate that to the bottom of the new half doors so that it will overlap the tailgate and give you a place for weather striping. I don't think you would have to weld a sill to your tailgate... just make a braket for the door latch
I'm assuming your using a one peice tailgate from the factory soft tops. If your using your doors to make the tailgate that's alot more work. I think the picture you posted is a factory tailgate. Looks just like the one on my 72 which had a factory soft top.
If I couldn't find a tailgate cheap I was going to just weld the two bottom halfs of the abmulance doors together to form a tailgate.
somebody makes a fiberglass gate, i'd tell ya who, but it was there when i bought it.
my hardtop is going to have the flip up top from the earlier tops.
I pulled the 2 half tailgate doors off my 74 to put a pair a 76 ambulance doors on. I might sell them but that would give you 4 doors on the back which might be a problem latching.
The one peice tailgate had 2 hinges on the bottom and 2 latches on each side.
Try this.. simple and effective.. I have the specs somewhere .. in fact I think the guy posted here on mud somewhere. Probably less than $50 in metal
The original Toyota dropgates are getting hard to find, and very spendy. Really not worth it unless you're an off-the-deep-end purist. Many other options.
IMO, second best choice is the homemade version. I like the one John Pardi made for his 40. About 3.5" thick, with a sliding door on the inside that, when open, reveals a propane stove imbedded in the gate! Prolly a bit more work than Bennett's post, but an interesting idea. IIRC Manafre markets a version of this. Form follows function.
Third choice would be to weld together two lower doors from a 74 and older, brace them until they moved as one unit, and relocate the hinges to use as bottom hinges. Less work than a custom fab, and more of a stock look. Not as great in utility as choice #2.
Last choice would be the fiberglass. Since I only ever hear the name Malotte when fiberglass is mentioned, I would venture a guess that is the mfgr. $OR sells the glass gate.
Last choice because I'm just not a fan of fiberglass. Kind of the same reason I have 5 guitars and none of them are Ovations.
THen you're back to finding hinges and latches. Latches are the same as tire carrier latches for the 76 and older tire carriers. I have made simple plates that could be bolted over the pre-existing amby door hinge holes and then welded the latch hooks to the plates to avoid excessive drilling. I've got the last set of NOS hinges. Not sure why. :confused:
