Anyone hear of an aftermarket lock mechanism for my 87' pickup tailgate? I have locking cap and would like to lock tailgate too.
Thanks
Ken
Thanks
Ken
Outdoor cabinet lock with 1-1/4" arm. Cable going from end of arm to linkage on one side. 2nd cable goes from end of arm, around 2 pullys, and to linkage on the other side. When the arm is up the cables are tight and the linkages can't be pulled to retract the catches. When the arm is horizontal the cables are loose and the linkages can move. No I haven't made it, but I came up with the idea when I was thinking about installing a tailgate lock. You could also use a cabinet lock to shove a rod into the linkages behind the handle, but I don't remember enough detail on that design idea. For the cable idea I was going to crimp the cables to the sides of the linkage rods. You also need a D shaped hole for the cabinet lock to keep it from turning in it's hole. This was for a '94 mini truck tailgate.or rig something up to immobilize it when you dont need the tailgate to open![]()
It's more a weight issue for the axles. There are a number of Toyota Mini Truck based RVs. Toyota killed that use due to to many of the makers overloading the rear axles when a reasonable amount of gear was added. I know a couple had to be driven dry with no water or sewage in the tanks or they were overloaded.Is it possible for my single cab 22r to push such a camper?
