Tail light harness connector (d/s rear fender well)
Seekonk, MA
97 fzj80 that has brake lights but no rear running lights including license plate and side markers. Found this and looking for help replacing the connector. Anyone know if these are available or what a good replacement might be?
This is a common situation with all the possible water intrusion culprits in the rear corners. Be sure to track those down. I had multiple offenders.
I would be tempted to cut out junk yard FZJ80 connectors (that look good!) and then splice on your wires, that you cut off.
One of two things: 1) the connectors should have a part# on them. 2) the manual or partsourq should list them and you can either purchase from Toyota if still available or go through Ballingers.
Reason for the alternate suggestion is there aren't many 80 sitting in wrecking yards (at least not around here).
My 96 LC has P/N:
81555-60321 (RH) SOCKET & WIRE SUB-ASSY, REAR COMBINATION LAMP, RH (SUPERCEDED BY 81565-60241)
81565-60241 (LH) (& RH) SOCKET & WIRE SUB-ASSY, REAR COMBINATION LAMP, LH (& RH)
Currently $28.87 from McGeorge.
Found the part # from a post a few years ago. This part# replaces the whole assembly not just the plug.
Cool that is still available but wrong part for what I need. Looking like either a 20 wire splice job or some aftermarket sealed 20+ pin connector will be needed. Rust sucks!
You may want to check with the fellas a Cruiser Yard (still an advertiser here, I think). I've bought small bits and pieces from them in the past. They may have a used loom with those connectors that they'd be willing to part with.
