I'm thinking about taking the Elocker from my brother's Prerunner and putting it in the front of my 80. What would i have to do to make it work? Do i have to switch to straight cut gears or can i keep the reverse cut?
well it's not a daily driver and id like to have a front selectable locker without buying one so... i only have time.
If you plan on the same gear'sidea: what the taco's : ?) its easy enough to just have to remove the ring, you don't have to remove the pinion. i.e easier than a complete regear. Swap in the carrier, paint it, back lash it, wire the connector and go.
Buying an ELocker
Let the ARB testimony's begin!
Holy ****... once again you prove that you have no clue what you're talking about.
YOU CAN'T DO THIS!
Gears are a matched set. Rings and pinions are married, you CAN'T interchange them, even if the ratio and diff are the same. This is especially true once they are broken in.
And for chrissakes... NO you can't just swap the hi-pinion carrier, the gears are cut "backwards". Sheesh...
e-parise: to answer your question, I also don't think it's worth the trouble to fix the steering issues. Your driveshaft will also probably have to be lengthened, and your pinion angle will be awful. Also, what will your brother do about his truck? You can't put your open hi-pinion diff in his truck, it won't fit. And even if it did, it's only a 2-pinion carrier, running on the "coast" side of the gears, it wouldn't last very long. He also can't install a plain open Taco diff, his axle housing is modified for the e-locker.
Buying anOTHER ELocker
(THE SAME AS THE RATIO YOUR REAR CURRENTLY ALREADY POSSES)
I guess since there are 4 "E" lockers some confusion may ensue...
What I meant was "Buying ANOTHER ELocker" as in Eaton,
WAY easier to BUY and swap a simple carrier than to go all junkyard wars on it!
Last time I looked, Eaton didn't make an elocker to fit a Toyota differential.....although I suppose that's beside the point.
which one?
I think Eaton has the clutch pack (vomit, barf) ltd slip switchable to spool
I want this one (collar lock though, the ramp balls momentarily disengage when you transition between fwd and reverse when its locked) open switchable to spool
