T-Case :boom: finally
denver
Boy do I feel silly, but my t-case finally ate it while driving around the neighborhood today. Glad it happened at home instead of in Buena Vista last weekend.
looks like one of my studs fell out from inside the t-case and shot out the bottom. I red locktighted all the bolts in this interface, nothing was leaking so there really wasn't a warning. I haven’t ran my cross member for a few months so not sure if that is related to the loosening. :frown: hope the adapter isn’t' jacked, some helicoils may be in order.
Anyway, I have a 4speed case lying on the shelf, anyone remember off hand what is required to drop 3 speed gears in it? I think it is just different thrust washers on the idler, maybe two on one side? poser? bueller?
I would make sure that the low speed gear is not jacked bud...
Usually when this happens, the gear gets damaged also....
I would verify that, and if it is jacked, and even if it is not, I would look at getting the gear from a vendor out here that will make the four speed case work behind that 465....
You are not really loosing that much low range. 1.99 VS. 2.3. The 6.5:1 first more than makes up for it. ;)
Would be easier and quicker.
:beer:
If you need another housing call Tim Hill. He has a couple dozen shells of different vintages. He also has numerous complete transfer cases (many with transmissions); non-split, split and Australian.
Home: 520-616-0304
Mobile: 520-240-3757
That would be a lot of ramen, I should go on a third world diet anyway to offset the beer/computer job.
But, Nah, I dont' want an orion. Too deep without much selection, if I did a change up it would be with a toybox, with a split case or maybe a mini case. I kinda want tighter gears on the street too...
stock cruiser cases are cheep or free, so that is the route I'll roll until i'm a big balla. :D I guess I'll use more locktight this time :idea:
90% of the issues that folks have with locktite that does not hold comes from poor prep work....if there is ANY oil/dirt etc, it will not hold, period.
Good luck!
-Steve
Good luck!
-Steve
X2
Second is using the wrong type for the size bolt/screw.
If you get in touch with a Locktite distributor you can find out when they are having a seminar near you. Well worth an afternoon spent.
well what normally happens is the case blows in two. So yeah the case is the weak point. The gears aren’t particularly strong, but as long as everything is in tolerance they should be fine. I did have a idler bearing fail a few years ago and it destroyed the gears. I put new gears into the now broken case. Basically my case was a time bomb, it had some spider cracks in it from the last incident, that is why my title is what it is. However, mine is not a good scenario to look at since I had a bolt come loose and do the deed.
