Switch Backlight Confusion - I'm Stumped
Salt Lake City
Finally got my JDM fog light switches wired up only to find out the backlight for them is super weak compared to the other switches. Before and after making the connector, I checked with a multimeter to make sure that the wire coming from the tail fuse for the backlight power was getting 12v and went down gradually as the Rheostat was adjusted and it worked perfectly. I pulled both fog switches and noticed that you could see some illumination coming from the bottom of the tiny bulb, and compared that amount of illumination to that of other switches in the dash. All switches are getting 12v where the bulb screws in and the bulb illuminates with the same light output in all switches. It makes me believe that the fog switch was for some reason designed to have a weaker backlight. I did notice that on the switch label, the part that is supposed to light up has a different pattern than other switches; it has a gradient label while the rest are solid. What am I missing??
Yep, also a bit underwhelmed with OEM fog switches brightness.
Edit: if it's truly foggy out you wouldn't want cabin lights making things worse.
I'm not an electrician, but if these are LED, could it be they are non-dimmable and are weak because of it?
Also, Toyota switched the ground, not the hot if that makes any difference or any sense to you.
They're Toyota branded incandescents
Please elaborate...
EDIT: Yup, I had an earlier thread where I was getting details about this and how the rheostat is the backlight's ground. Here's how I set that up
They might be using a 60mA bulb in that location, whereas most other switches have the 80mA bulbs. Have you tried swapping-in the bulb from the defrost switch?
