1. Asked my local Toyota Dealership to loosen the valves when it was in for the seatbelt recall. They said the valves were "frozen" WTF? No solution!
2. Sprayed the valves for 2 weeks with PB Blaster - no luck
3. Had my mechanic take a crack at it. He used a small torch, "Matco Tools" hex bit. Managed to break the inside valve loose and broke the hex bit off inside on the outer valve. He was able to remove the broken bit but didn't want to break a second bit. Told me to keep spraying it with penetrating oil.
4. Mechanic tried it again after I sprayed I sprayed it for 4 days in a row. He bent this hex bit tool and said he didn't want to break or strip anything valve screw and gave up the fight.
5. I have decided to drop it off to another mechanic that I haven't used in awhile and let him take a crack at it.
It sucks because I purchased my suspension system prior to attempting to release the KDSS valves and now i am stuck with over $2,000 in parts I can't use. I am hoping...praying, that this shop can install the coil springs, shocks, struts and UPC's with only one valve opened 3 turns. Anyone actually replace a suspension successfully without the KDSS valves opened? Just wondering what one valve oped does if anything?
