Swapping Axles e-locked/non-locked
Washington
So I have read it here for many years about how easy it is to swap e-locked axles to a truck without factory lockers. I have 2 LX450's, one locked and one unlocked. The unlocked truck is the one that is kind of built up for offroad so I figured swapping in the e-locked axles would be a bonus, and the other truck would get the unlocked axles that I would have rebuilt with limited slips.
I have heard that all the LX450's have the body harness for lockers, what else is needed for the swap? I would think everything would easily be sourced from the e-locked truck but if it is easier to just buy new like; switches, bulbs, patch harnesses I would prefer to do that.
If anyone has done it and not just second hand experience I would love to hear any issues you ran into.
Thanks!
A friend tried swapping axles on his LX, he did not have the wiring harness that goes from the magic dial to the locker ecu in the dash. He found that info somewhere here on 'mud, but I just took his word for it.
I believe this was just the LX models as well, not the LCs
Ok cool, I think I should be able to pull that from the Black LX I have. I think having the two trucks side by side it should be pretty easy. I just didn't want to have to pull the entire wiring harness out, if that is the case, I am not doing the swap.
non-locked 97 LX450 body here.. dash portion of locker switch harness was there. There are three things you can pretty easily look for to definitively determine whether the "hard to swap" stuff is already there.
1. Checking for the dash harness is easy.. just pull the knee pad on the driver's side and look for a flat plug with 4 pins in a row. This was in both my non-locked 94LC, and my non-locked97 LX450. It was taped back against another part of the dash harness, but it was there. I thought I remembered 4 wires but EWD only shows 3.. red/black, black/green, blue/black.
2. Also the front locker harness should already be in place in the engine bay near the cruise control module. It'll be a small gray rectangular 6-wire plug IIRC, maybe with only 5 wires installed. Blue, blue/red, blue/black, blue/yellow, white/black. This was also in my both my non-locked 94LC and my 97LX450.
3. The spot for the locker ECU will be by the auto antenna relay in the driver's kick panel. It is pretty far up in there.. Gray 16-pin plug. Shouldn't be connected to anything. Same thing, installed in both of my non-locked rigs.
I also went to install my locker floor harness.. turns out the 97 floor harness already had everything in place for the lockers, pins correct, I didn't need to change it at all. Only thing I really had to change was the harness across the rear underside of the body, and run the e-locker/ABS harness along the frame rail then to the crossmember
So, assuming yours is set up like my originally unlocked 97LX450, the complete list of what you'd need:
magic dial
e-locker ECU
both axles
front adapter harness from axle to 6-pin connector in engine bay
rear harness across underside of body
Rear wires from axle to cross-harness. (Can't remember if this is two parts or one)
Might not be a bad idea to get the driver's side floor harness from under the dash to the rear of the body but in my case it wasn't needed. I do know that my 94 land cruiser did NOT have the e-locker wires in this floor harness, but my 97lx450 did.
My swap was into my sig LC, but the old green 450 I had was a '97 with the floor harness present.
Funny thing, now that I think back I never stopped to look if the dash harness (switch, cluster provisions, ecu pigtail, firewall socket to fr harness socket) - was there.
I was told long ago LX450 floor harnesses were all lockered, mine was despite not having & so were 2/2 in people who had PM'ed me about really doing the swap, esp if you were doing it into open diff housings.
My old 450 had dual air lockers from a PO, switches for the air comp & each locker were just the ARB ones. Never felt like swapping in a rotary switch so it never dawned on me the dash harness may not be present.
Seem to recall newrear axle harnesses are NLA, but that's not gospel.
You're welcome. Actually it's nice to squeeze out the sponge that is my brain once in a while.
I did forget on my list.. the two bulbs in the cluster. Both my 94LC and 97LX had the appropriate tinted screens but tape over the bulb sockets.
