The important value is the one at level N, after a move up from Lo. The pressures are all measured at the pump, and showing the pressure there at the exact time when the front or rear reached it's height. So, the pressure measured when it reached Lo is not really of any use, but it is normally much lower than what you report here. And that the rear press after going to Hi is lower than at N is puzzling.I just hooked up the teachstream cable and got some readings by moving the suspension from low to N to high. Pls see if this makes sense as I'm not familiar with these readings.
1). Switch Low -> N (Front - 7.3, Rear 5.5, accumulators 10.4)
2). Switch N -> High (Front - 9.5, Rear 3.2, accumulators 10.3)
3). Switch High -> N (Front - 9.6, Rear 3.3, accumulators 10.3)
4). Switch N -> Low (Front - 9.6, Rear 3.2, accumulators 10.3)
5). Switch Low -> N (Front - 7.4, Rear 5.2, accumulators 10.3)
At the N position I noticed that the front angle sensor FL was 0.0 and FR - 0.4 and Rear - 0.5.
No DTC error for AHC. Only have 2 DTC errors under Immobiliser - B2780, and another under tilt/telescopic - B2602 (key unlock warning switch).
Any help is much appreciated. Thanks.
Always read the pressure a while after the suspension has reached the N level, like 20 secs after, to be sure.
So, at step 1 and 5 (I numbered the lines for you), the front is 7.3 to 7.4, which is at the upper bracket of the specs. You ought to tighten the TBs a bit, but this issue should not lead to the situation you describe as a very hard suspension.
The rear pressure is too low (5.6 to 6.7), which leads me to think that your rear height is too low. There is a procedure in the FSM for checking the height -- it is not difficult to do, but it takes a bit of consentration to understand, and to find the points to measure from.
If you actually got new globes (easy to check the # of graduations), I tend to suspect the actuators, like cruiser03 describes in another thread. If you go through the other input tests of the ahc system, and all is ok, there is in the end not much else to suspect.
