Hi,
I been having a stiff suspension problem for a long time. My SUV suddenly gets into a mood where it tightens up its suspension and it feels like the vehicle is driven without any shocks / torsion bars / spring. Everything in the vehicle shakes, starting from the dashboard.
I tried different solutions over the last 2 years (even replaced the accumulators with aftermarket units), and nothing seemed to solve it.
Last week I simply lost it (I mean, I didn't get this SUV to have such a bad ride) and I went and purchased all the parts I can think of for the suspension and replaced them. (almost all parts are Toyota OEM except for the ball joint and rear control arm bushes ). List below.
01) Lower arm ball joint 02 (Febest)
02) Lower arm bush 04
03) Front wheel bearing both side4
04) Engine mount 02
Rear Spring Coils 02
05) Gear box mount 01
06) Front stabilizer bar bush set 02
07) Rear stabilizer bar bush set 02
08) Front axle boot inner 02
09) Front axle boot outer 02
13) Tie rod end set 022
14) Front upper arm ball joint 02 (Febest)
15) Front upper arm bushes 04
18) Rear upper control arm bushes04 (Febest)
19) P/S rack boot 02
20) Steering cross joint 02
21) Front shock absober 02
22) Rear shock absorber 02
23) Suspension accumulators 04
24) Suspension oil
After replacing basically everything I can think of in the suspension, I finally got my SUV out of the workshop today, to be disappointed by the stiff suspension returning. The ride feels much more sturdy (with all the new bushes). But the stiffness still remains. I've almost had it with this vehicle!!!
I do run 20' for my tires. 20' x 285 x 55. I know this effects the ride comfort but I really don't think it can effect this badly.
2005 Toyota land cruiser (Cygnus) - Same as the 2005 LX470 (Japanese domestic version).
I use the same parts as LX470 - 2005
Tires - 20/285/55
Suspension - Accumulators x 4 (new)
- Shocks x 4 (new)
- All bushes (new)
any thoughts / suggestions / help is greatly appreciated.
Thanks!!!
04) Engine mount 02
24) Suspension oil
Tires - 20/285/55
- Shocks x 4 (new)
- All bushes (new)
Thanks!!!
