Sumotoy Zero-Boost SC Mod
Chicago
The purpose of this Mod is similar to the Zero-Boost Turbo Mod described in a previous post, but this for the Supercharged Truck owner looking for the same goal of zero-boost driving. Several have indicated the desire to have no boost for wheeling and/or for lack of available high grade gasoline. This is a simple mod to do to a Supercharged truck - total install time was under 3minutes - and 10 seconds to remove. The Bypass valve for the SC is located to the Drivers Side of the throttle body, just forward of the T-body itself. The first shot shows the Valve in the Closed position, as you would see it with either the truck off, or the engine under full boost.
The second shot is with the valve zip tied open. I daisy-chained two 8in zip ties and reached under the SC near the Air Cleaner to feed up to the valve swing-arm plate. I road tested the mod, and got the results I predicted a year ago. The SC will generate some boost on the guage, but using a atmospheric-calibrated inHg aircraft guage I still have installed in the truck, the actual boost over atmosphere is less than 1psi under any load or rpm conditions. I would suggest the same test results would be found in the Sumo Zero-Boost Turbo Mod as well, since large enough bypass valves for 'true' zero-boost are tough to justify. Less than 1psi under any load should be a good enough target, given a blower fan is installed.
Just for S&G, I also tried removing the belt to compare results. The SC pulley does move under rpm load, and attains a true -0- boost, but this mod is a restriction to the intake as mentioned in other threads. I was seeing a rise in intake temps higher than the bypass valve mod which appears to confirm this is a restriction. I do not recommend removal of the belt, as the restriction dictates this appears to *not* be the same as running a truck without an SC. And is not equivalent to running an SC in Freewheel mode (belt on - bypass valve open). The intake manifold temp values without belt installed were less than a 6.5psi TRD, but I'd have concerns at high rpm under load with crappy gas.
HTH
Scott J
94 FZJ80 Supercharged
Nice, I happen to keep a few zip ties in the back cubby.
If I ever become jaded with the S/C I could do this mod to help me realize what the LX used to feel like.
So, simply doing this mod will allow you to run crappy octane fuel with zero boost? Nice.
Sumotoy Guages currently on board
FYI,
Here are the guages I routinely install in boosted cars for testing and calibration. Both are FAA certified aircraft guages. The inHg one I use as a temporary install to accurately and finely tune/identify/measure boost levels in relation to atmospheric pressure (notice it's a nice day today in Chicago). The Intercooler in-differential-out temp guage I normally use to calculate turbo and intercooler efficiencies. For my SC 80, I installed one probe just forward of the Air Flow Meter, and the other probe is mounted in the Intake manifold. The difference would be the temp rise due to boost. Or specific to the 'pulling the belt' mod - the temp rise due to rotor obstruction.
The white guage at the top of the lower photo is a liquid filled 15psi fuel pressure guage I normally use for a boost guage.
Cheers
Scott J
I can see the benifit if your driving and cant find decent gas.
I have no issues with the SC Boost and wheeling and see no reason to bypass. Now the turbo has a delayed reaction and that could be a problem in some cases.
It's a good thread and helpful with the pictures,
Thanks for the pictures
Great work Scott. It's hard to argue quantifiable data.
Your diagnostic tools would be great to quantify the actual temp changes involved with adding an air/air intercooler to the 80 series S/C. In this cold weather, my intake runner rarely gets very warm. However, that thing gets piping hot when it's warm outside (>85*).
I'd like to add a Blarsen intercooler eventually.
The main reason for installing the guages, was to do the Blarsen-type IC. I have the hood scoop, the intercooler, the piping and too many turbo audis to work on. The guages installed give good feedback for a variety of tests, and worked with this mod just fine too. Very little measureable boost with the SC bypassed. I suspect even less boost with a torque converter lockup mod... I'll retest that theory when I finish the torque converter lockup modification.
Romer, I agree that wheeling without boost makes no sense to me (turbo or SC actually), but I try to keep this mod less on judging why, only presenting how. I don't ever see actually doing this mod for myself. That said, the bad gas scenario is a good one I hadn't thought of before last years thread in this context, and applies to either the Turbo or the SC mods I presented.
The SC rotation with no belt attached was mildly interesting to note as I took the time compare this mod, and the actual restriction could be mathed with only measuring nose cone rpm changes vs known scroll output per revolution. But the intake temp rise concerned me with no belt attached. I appreciate the tolerance to my self-ascribed modifications. My motivations are simpler than many think, it's not as much ego, as easy for me to recall my tech posts on a variety of forums I'm on. Ignore that potential offense would be my advice, and I hope the tech parts are useful, repeatable and addresses the target identified.
Scott J
'94 FZJ80 Supercharged
Let me do my duty of :bang::bang::bang: yet again; with a properly setup and sized turbo there is no real delayed reaction - the boost is smooth starting from somewhere around 800 rpms, it is manageable, predictable and almost always helpful to overcoming the obstacle at hand. Of course an improperly sized and setup turbo will woosh on and probably present problems offroad. I see no reason to d/c boost once one's got it. Okay, back to the regularly scheduled program. :cheers:
My apologies Shaun, not having a turbo I defer to your comments. I was going by what I was told by a well known south african, but then he was drinking at the time:D
Ahh, yes, and also prolly referring to the 100 which I have heard him say has the "wait and woosh" effect. :cheers:
No worries whatsoever though it is just my "patriotic duty to the turbo nation" to protest the ugly stereotypes still out there! :D :grinpimp: :D
I don't see any reason to disconnect for offroad either, said so many times in other threads (and I don't care if the turbo is properly sized). Without 'judging' the reason for zero boost, I have only presented how to do the SZ-BM to both a turbo and a supercharged 80. I do see the benefit for substandard/bad gasoline possibly found in the remote areas of Mexico. That said, when I used to go down there (before Magna- 88octane and Premium 92 octane), the trick was to bring gas filters or rig them up in parallel, as 'crap in the tank' was more literal.
Diverting to the 'other' reason for a moment... Water separation is still a problem even with the higher octane fuels Pemex sells, mostly due to storage duration, compounded by the inherent properties of water saturation in ethanol blended gasolines. But I never thought that was a octane booster solution, more a 'dry gas' solution. What you are trying to do is get the gas to absorb more water so the motor doesn't ingest a high/sole concentration of separated water. The object is really not so much increase the octane of the fuel, the fuel 'portion' you have has enough octane. My understanding is that Isopropanol additives ("Heat" and "Drygas") solves the water saturation problems better than the "-ene" based octane boosters do.
Scott J
Diverting to the 'other' reason for a moment... Water separation is still a problem even with the higher octane fuels Pemex sells, mostly due to storage duration, compounded by the inherent properties of ethanol water saturation in gasolines. But I never thought that was a octane booster solution, more a 'dry gas' solution. What you are trying to do is get the gas to absorb more water so the motor doesn't ingest a high/sole concentration of separated water. The object is really not so much increase the octane of the fuel. My understanding is that Isopropanol additives ("Heat" and "Drygas") solve that better than the "-ene" based octane boosters do.
Scott J
Having lived a long time (at least for those used to 18month tours, 30+ months or so is wonderfully long) in Central America I'll agree that octane isn't the problem, water is and I'll agree that a thing of "heat" (aka drygas) was used almost every other tank while I was there. Additionally tanks were always filled at the halfway mark by motorpol suggestion and we always had a fuel filter or two along with some "squirt start" in a can in case things really got plugged and we needed to prime the engine. Lots of fun, lots of fun. Ohh, I was completely clear that you don't think that this mod is necessary, just that for those that wanted it, here's how to try it. I was just adding another "vote" that after one has boost, removing it is sorta silly. Anyways, back to the thread's topic ...
