here is the back passenger corner, it is not finished but i thought i'd put it up
just out of curiosity, when you cleaned all that up, was there a bunch of bondo there? i've found three cruisers with a bunch of filler on their rear pillars.
i think you might have been the one that told me about the rockers being shot, i tried to find the post but couldn't.
![022_semi[1].gif 022_semi[1].gif](https://forum.ih8mud.com/data/attachments/222/222934-34e35432e5d42f9f0f45c2353e1f7608.jpg?hash=NONUMuXUL5)
I cant tell colors from the pic of the fuse block, but if you look at the right side, you will see that there are two groups of three fuses. One set is hot all the time, the other is ignition hot.
Connection of the loose wires depends on what circuit they are for, and whether the top or bottom group of three fuses is always hot.
things like wiper, heater, blinkers, etc are ignition hot.
headlights, hazards, brake lights, are constant hot.
looks like old moweri was digging through parts, and i don't know if this belongs to an old mower, or the pig.
I would recommend a new throttle cable, SOR.com has them for cheap.
thanks
and i have what i think is an electric choke? there is a black wire with yellow stripe, looks like the perfect size to bolt to coil with the black/yellow wire there?
any idea?
