Y'know, I have that same switch, attached to a pair of long, thick leads that end in battery terminals type thingies that go to the battery ground...
I found it at a BMW dealership.
Apparently all BMW come across the pond with one of these....
The dealer pulls it off and throws it away.
Or they used to anyway. I've had it a few years now.
I grabbed a few, gave most away, kept one for myself.
Maybe drop by your local dealership, see what you can find if you ask nicely?
I have one of these for the "ignition switch" for my VW Baja project:
clicky:
A crew chief that I used to work with had one with the key in the front fender well behind a debris baffle. Anytime we were going to be out of eyesight of the truck while in Baja he pulled that 'key.'
Simply interrupting one of the grounds for EFI bits will disable that portion of the system. I'd look to see if the injectors have a ground on the engine. Some do, others don't.
Before the days of OE clutch pedal starter disable switches I put such a switch on the brake pedal of a friend's hot rod. It also had a toggle switch in the circuit hidden under the B&M shifter cover.
