Stupid Noob Backspacing Question
Tenino, Washington
I appologize if this has been covered someplace already. I have been searching and found that everybody says you need 3.5" BS or less to keep the wheel from rubbing the caliper. I have a drum brake front, will I also need to have the 3.5"BS?
Thanks!
Thanks!
And if you are going to run aluminum rims, the actual rim part of the wheel is thicker than a steel rim and may still rub on the TRE. I had Outlaws on my drum brake setup and had to also use 1/4" aluminum spacers to keep the rim off the tierod.
GL
ed
