stuck screws...
Littleton, Colorado
im having some problems getting some bolts/screws out of the engine. ther stuck on what i think is called the timing plate. its behind the cam shaft gear and crankshaft gear (both are out) the screws are big, they are flat head screws/bolts. im not sure how to get them out ive sowked them in penetrating oil over night, and tried the next day, ive tried the air ratchet. ive tried a normal screwdriver. what will work?? also i dont want to damage the block, so what will work with out damaging it?3and yes i need to take this off because a gasket goes behind it.
Those impact drivers are great, but sometimes even they can be a pain and can bugger up the screw.
You can get by without one too. If you have tried the air ratchet, can I ask if you have a 3/8 gun? Get a 1/4" socket and fat flat tip bit and that usually will get em out. Used it on stubborn windshield hinge screws and it works great too.
Or there is the speed handle method doing the same thing. I fought with those same bolts a while back, it sucks.
Hit up a decent auto parts store that has toos, and see if you can find a 1/2" drive flat tip driver.
Snap on makes a nice one that I have used for years and works on these very well. I am sure that someone else makes something similar.
Good luck!
-Steve
Aren't there 2 or 3 that are peened or staked? I use a cold chisel on mine to remove the bur of metal that was holding them.
Ed
Have you tried a breaker bar and a socket?
I have a cheap torqu wrench (1/2" socket) that works for me on things like this. The extra long handle gives you that extra leverage, and when it doesn't a hammer nudges it a little more.
Your welcome to borrow it Max, or my breaker bar.
Staked means someone put a material in them so it would not back off, similar to locktight. How you take care of stavked screws is to heat it (small blow torch) and loosen it when it gets hot. This method also works sometimes when they are not stacked.
You can get the small propane torches at any hardware store. You will need the proposane bottle, nozle fitting and a ignitor (Creates spark to light torch. You can borrow mine if you want.
HUH????
The staked I'm familiar with means that part of the nut or screw has been punched with a chisel or some other means in order to keep it from moving. Like this...
Thread lock/loctite is different than staking.
I know what you're talking about, When I did my engine rebuilt I was not able to remove that freakin plate. and I tried everything, I concluded that these bolts where rusted in and it was not worth the trouble to remove them. I end up lifting the edges with a sharp flat screw driver and stuffing RTV. No pretty but after trying to remove these bolts, broken several screw driver tips, whether it was the BFW or the impact wrench (preffered) the slot ended up mangled after three tips broke. Mine was really stuck, and they are still. The RTV trick still holds in there.
Look closely at the stubborn screws, you will find that the surrounding plate has been hit with a chisel....aka STAKED. Rusted?, I doubt it. Beat back the staked metal and you should be good.
GL
Ed
GL
Ed
that was about a year ago... too late now. to get to that plate I'll have to take the camshaft out... no chance if it's working now...
I checked the pics I took when I worked on the engine and did not see anything affecting the screw heads... mute point now.
