stuck screws...
HawkDriver said:
HUH????
The staked I'm familiar with means that part of the nut or screw has been punched with a chisel or some other means in order to keep it from moving. Like this...
Thread lock/loctite is different than staking.
Ok, In the manufacturing for the aerospace industry, Staking refers to a compound used to keep the bolt from moving out. Generally an epoxy applied after the proper torque is set.
I guess like many things, there are two definitions. Never heard of the one you described, but then I am in the Aerospace industry, not automotive.
Learned something new :beer:
Checking for peened in staking - it'll be there if the engine hasn't been apart before. I'd try my large Snapon screwdriver like Poser's (gotta' hold it FIRMLY in the slot) that has flats on the shaft that I can use a crescent wrench on and if that didn't turn them I'd go get the hammer impact wrench like 'getsUthere's that WILL turn them.
Your radiator is out, right?
I've always had good luck on the hand impact wrench. I've busted bits for it but I have yet to mess up a screw that was hard to remove.
after un-staking the screws try hitting them with a hammer and then tightening them. Sounds dumb but 20 years a structural mechanic tells me it works.
