Stuck rings
Knee deep in hookers and gin
My rescued 40 project is going well. I recently was given a 79 FJ40 that was rescued from a junk yard in 1985. It sat behind the barn under a willow tree in a swamp for the next 20 years.
I stripped the rotted tub off and got the front clip off this morning. For the heck of it we put the 3/4 drive on the pulley nut and it turned. :D Threw a battery on it and it almost cranked. Replaced the starter with a later model one, topped off the oil and swapped out the carb. We have a nice crank speed and spark now.
It has poor compression. Between 50 and 75 psi across the board wet.
I PB Blaster-ed down the spark plug holes. i suspect the rings are stuck. Anybody got a secret for popping them loose?
I favor Kroil to free up stuck stuff myself. I have also heard folks using Coca-Cola, the phosphoric acid in it will eat at deposits to free things up. But I am not sure how well it will work on stuff that is moving. ATF has also worked for me on vehicles that have sat for awhile.
Otherwise pop the head off and slide the pistons out the top, clean/replace rings and put it back together. Might be more work than you're interested in though. :)
Good luck with it!
Nick Jennings
Have you tried Seafoam, Gumby? If your rings are crudded up, and that's the reason for poor compression, that might do the trick. If they are corroded badly, though, I don't see how you can get by without at least reringing.
Well, Gumby's engine can't be seized if he has good crank speed and spark. The problem is compression, which to me means corroded, worn, or carboned-up rings. Or, more likely, all 3. :crybaby:
Nope, not seized. i can't imagine how, but it spins OK. I'm hoping the rings are stuck in the lands.
Thanks for the offer on the Kroil, Yooper. Let me see how the PB works. I've been wanting to give Seafoam a try as well. I've heard lot about it, but have never tried it. If all that doesn't work, i may give ya a call.
Seafoam reduced the smoke from my used but healthy 350 to almost nil after it had sat for 2 years. I'm pretty sure I had gunked rings.
It was just Gumby'd up a little bit.
Hey Guys, So how does this seafoam work, this is the first I have heard of it. I have a 68 fj40 and the rings could use some help. Do I just spray it in the spark plug holes and that is it, or do I have to do something else. Thanks for the info guys.
Chuck
I have had good luck with Marvel Mystery Oil in old engines before turning them over, but it seems you have it figured out.
Dan
