Stuck in 4x4
Dallas, TX
My t-case (4 spd, 3/79) has been stuck in 4x4 from day 1. I think the problem is the shaft (SOR 074-17 below, transfer shift shaft). It is stuck in the 'out' position. Is that what allows you to shift from 2h to 4h? It seems from the way the shift lever works, this is the part that makes allows the t-case to go from 2h-4h. I tried to beat it back in to no avail. I can switch from 4h-N-4l.
If your hubs are unlocked it should be easy to shift.
If it has been stuck that way a long time, the shaft on the actuator (part 17) may be corroded. Just remove it, clean it, grease the shaft and reinstall it. If you want to get it out of front drive quickly, just tap on it with a mallet so it goes back into the case.
Chances are, having the front drive engaged has nothing to do with it whining, which is more of a gear noise.
I think there is a grease fitting, and yes putting it in gear and let out the clutch slow while trying to shift the t-case. I usally will let it roll slow trying to shift going into first then backing up. It took me a week to get mine into low range. Now it shifts so much easier. Work it in and out every so often.
Unlock the hubs and roll in reverse a bit as previously suggested. Put it back in nuetral and the transfer will usually let you go back into 2H. This happens with the hubs sometimes too. Rolling back and forth in and out of reverse seems to always do the trick on both my 40 and 60.
Mine whines. Like they say go back a bit with hubs lock its way harder. After Look at the shaft and lube it. I did it and work for a bit. but I just have my rig on 4x4 all the time doesnt see to much street. One time I had to hammer the (# part 17 in ) so I could get it in 2 wheel drive and they told me to clean the shifter. that helped alot to
Eric
Drain the xfer case and pull the 4 bolts out of item 16 (you may have to loosen the linkage the fish #16 out of the nose cone).
From here it should be easy to tell if it is the shifter (#16) or the shift collar that shift fork #15 is supposed to move......
Good luck
PMK
I have tried all the suggested methods but still can't get out of 4x. What is the best way to take the shift rod out to clean?
Good luck
PMK
Don't know what the inside of your transfer case looks like (mine was an earlier model), but on mine all I had to do was replace the shift collar that was bent, and it worked after that.
I fixed this by taking the assembly apart and lubing the hell out of the shaft. In doing so, the spring got lost (part # 43). What purpose does this serve?
Also, do I need the boot (part # 20)?
Howdy! Yup, it is a good idea to keep the boot in the shaft, as that keeps it from getting really bad stuck full of crud. I always put a finger full of grease inside the boot to keep it well lubed. The spring and parts 41, 42 ,43, & 44 are the detent system for the front axle engagement collar. Helps keep it all the way in or all the way out of gear. Definitely another good part to have. John
mine wouldnt come out of four a cople of weeks ago when it snowed. i went under a taped the shaft wile a buddy pushed on the lever and it got un stuck then changed the fluid and has been fine sence. i think it was a bit of crude jamin it.
