So I was taking the 15th Head bolt to 90 ft-lb. tonight when all of the sudden it gave way. I assumed it was old and sheared off. I quickly realized that was not the case and the I had torn the threads out of the block (I guess) the bolt backed right out and will not tighten past about 20 ft-lb now. Is my only option to drill it out to 5/8 or something and re-tap it? I'm really hoping someone has an Indian trick here... I thought about running a 13x1.75 dye down the bolt and seeing if I could convince it that it had more thread. However, Craftsman tap/die set only goes to 12mm. Any ideas?
