Yes, I have been reading and researching this for months now...
I have a few stoopid questions about installing TRE's that I have not been able to answer definitively. Flame suit on, please advise.
1. What is the proper torque when installing the castle nuts on TRE's? Does it matter? As long as I get the cotter pin in, and its tight, its good enough right?
2. If I tighten a TRE, I should never loosen it unless they are being replaced, right? I think I tightened one too far, and then loosened it, but now its sloppy... looks like I have to crank it down at least as far as it was previously installed. I ended up looseening this TRE because it is the one that connects the Relay and Tie rods together. When I cranked it down it was tight and the hardware on the rods was touching/binding. Advice?
3. ...AND on one of the TRE's, the castle nut and stud are moving as one. Great. If I can separate these should I still use this TRE?
These are new TRE's and I would love to make 'em work. Working on a mostly stock 1977 FJ55. Any help, advice, or smart ass comments welcome.
I have never had so much fun with a one banana job. Yay!
Cheers, Carlos.
Cheers, Carlos.
