Just wondering as I'm restoring this 74 if putting a new aluminum radiator in ($200) vs re-coring the OEM one ($400) would have a negative effect on the value?
With the stock 6 cylinder you really don't need an aluminum radiator:
(1) Copper radiators help keep cooler temps down (i.e. 210 down to 190).
(2) Aluminum radiators help keep hotter temps down (i.e 240 down to 210).
Information from a sales rep who use to import both copper and aluminum cores for the USA radiator builders, plus he didn't have an ax to grind either way.What?![]()
Is there a different part number for a 4 core?Yes go the OEM 4 core, the originals were 3
I did not see any comments here on the load of Al crud that gets transported into the iron engine from that alum rad. Copper tends not to do that at all, unless it is in a 600 psi/800 deg F environment. Al will do it at ambient temps.Have sharpened axes, not sure what it has to do...
For the radiator argument, more efficient cools better, has more capacity, running 190F or 240F makes no difference.
Copper has better heat transfer, end of advantage.
Aluminum has manufacturing advantages, allowing for more efficient designs to be made.
The most efficient radiator is single core with a large surface area. Due to fitment, this often isn't possible, so cores are stacked, but each core is progressively less efficient than the one in front.
Copper tubes are commonly ~3/8" deep, aluminum is commonly made several times that, tube and fin spacing is commonly significantly tighter. This adds up to greater surface area, a two core aluminum being more efficient, having more cooling capacity than a four core copper.
Coolants now days are fully biased to aluminum, with little to no regard to copper, why would they almost everyone one runs aluminum. So copper radiators are not well protected, especially the solder, corrosion blooms and being eaten away, shortening life.
Now days my first choice, when available, is aluminum/plastic, second is full aluminum. The only way I would run copper would be a classic show car, if points or $$$ are going to be lost.
@tls3601 I would greatly appreciate that very much!@SW20 I can look up the part number for you. I definately think it is the way to go. PM me a reminder
