Still wandering, caster still?
How are you increasing a degree? New plates? IC I see dobinson makes a 5 degree plate. I guess it just depends where you are starting from.
Custom arms
Be careful with 5° plates I have and many have tie rod clearance issue with 4° plates
My 80 had close to zero castor before I reduced it's lift. Now it's running just over 4 degrees. The factory spec for pre-8/92 is under +2 degree while 8/92 up the factory spec is +3 degrees.
The most critical thing with an 80 would be the toe setting.
And good quality/condition bushes in the radius arms and panhards.
US caster spec on late model 80 is 2° - 4°
I run Dobinson 4" flexi coils and sit at what I consider a 4" lift height. I also use my caster plates which add 7* of caster and expect the actual caster reading to be around 3*. It drives perfectly fine at speeds up to 95mph for hours at end. I haven't pushed it beyond that.
I had a real bad wondering issue like you and with 305k on the clock the steering box was shot.
The part that was worn out was the valve assembly P# 44120-60180 and costs around $600.00.
That part is like 90% of the gear box and while fixing it yourself will cost more than a rebuilt unit from autozone that part will be factory fresh.
It made a huge difference all around with consistent tracking, less turning effort, especially off road and no burning of the fluid so far.
Does you know of any rebuilder that checks/replaces the above part? Would "valve assembly" be what you would ask a rebuilder if they replace?
That's what Toyota calls it. Technically I think it's called a cyclic ball screw. And you need more seals than what comes with that psrt to replace it. I had a rebuild kit on the shelf so I used the seals out of that.
Pretty sure this is the issue. I installed a bolt and nut like @Tools R Us did and drove a bit, still wondered around. Question while I brought this to tools attention as well, does the front bolt need to be installed? Thinking of building a permenant adjustment nut with a plate to sit on top of the arm. There is constant upward pressure unless you are flexed and this would allow more flex would it not? And make castor easily dialed in
I don't think that's a good idea
Or instead of removing the bolt completely, slotting the hole in the correction bracket and just loosening the bolt making castor adjustments with the adjustment bolt and tightening again? Sorry, boring day, just thinking
There's easily an inch play either way before the pitman arm moves.
This is play at the steering wheel?
I believe the spec for steering wheel play is 40mm (iirc), so 50mm (2") is not terrible
Correct.
Once the play in the steering box is taken up, is there play at the tie rod ends? You had doubts about them, but don't stay if they are good or not.
Also, while someone is tuning the steering wheel, check for play at the panhard bushes, and also check radius arm bushes.
What ever came of this issue? Im having similar problems and am trying to narrow it down.
