Still wandering, caster still?
Chattanooga, Tn
Checked preload on bearings, relatively new trail gear HD steering kit, knuckle studs torqued. with 4" lift, checked steering box adjustment; tightened it and made little difference. Only thing on my alignment that I see is the cross caster of half a degree. Was going to adjust to 0 if anyone thinks that will matter. Should I go up on the passenger side, or down on the driver side? And how much to adjust to make up for the half degree? Or is this even a problem? Thanks.
looks ok to me. check to make sure the panhard bolts are tight at both ends and for a frame crack where the steering box attaches to it.
No cracks. Everything is tight on panhard. From what I've read in the trail gear tie rod ends, wondering if that's the issue. They seem to have some play. Waiting on a buddy to come turn the wheel for me while I check things out
Using wheel spacers?
Had my son turn the steering wheel back and forth while checking underneath. There's easily an inch play either way before the pitman arm moves. Pretty sure original gear box with 314k on it. Time for a rebuild?
Your truck looks pretty light I would give 34psi a try and note any difference.
Two inches is out of spec, if the box was rebuilt with proper preload on the bearings you'd definitely see an improvement. 'Wandering' is a vague term though, usually associated with alignment.
So what is happening is I can be driving straight down the road wheel straight and it will start to run to the right. Straighten back up and it will run to the left and so on. It has no "pull" in either direction like an alignment problem. If the gear box is due for a rebuild I'm guessing that slop is allowing the wheels to guide the steering wheel instead of the other way around?
Have you driven other similarly set up 80's for a comparison? Bad tires can also do what you are describing. Steering box is for turning not to keep your rig going straight.
I haven't driven another. Had the same issue with my ko2s, now running falken atw3. I'm not sure I've ever driven on a perfectly flat and straight road before, but most of the roads around here have some crown to them and aren't straight, even in my work truck 2018 tundra, I can't just let go of the wheel and hope it goes straight down the road. The input from the steering wheel is definitely off the mark. I'll lower the psi today like you suggested and look into rebuilding the gear box. With family, bumpers, sliders, winch, tools and spare I tend to have 750-800 pounds in it on most drives.
Tire pressure can do a lot - when I searching for the ideal pressure on my new brand tires I upped the pressure on a trip and let my wife drive and she was like whats wrong with this POS its all over the road. Now at 7000#, 35's, 4° of caster I run 35psi and track great.
Attached is a PDF with more tire info than most want to know but some reading will show most run too much air based on tire size and vehicle weight.
Attached is a PDF with more tire info than most want to know but some reading will show most run too much air based on tire and vehicle weight.
thanks.
Your 4* of castor, thats another thing I came to wonder about. Should I up it? My castor specs in first post
thanks.
I do know one can easily notice the difference between 2° and 4° but 3° to 4° :meh: With that said I a huge fan of caster looking to increase mine to 5° because there is way less steering input needed. I run 5° on my LX470 and ran 7° on my old 40 and both steered excellent at 100. YMMV
Most roads will push the vehicle in one direction or another, but on a flat road the drift should be minimal. If there is a bias to the road, you compensate with a little pressure on the wheel to counteract it. What you are describing, wandering in random directions, does sound like a caster issue. Good caster will naturally point the wheels forward, lack of caster will allow the tires to unpredictably wander more.
I believe the spec for steering wheel play is 40mm (iirc), so 50mm (2") is not terrible. My interweb guess is that you have less than ideal caster for your rig. Caster can affect vehicles and drivers differently, so there's no 'perfect' number.
Thanks. Going to put a caster adjustment nut on the mounts and see if adjusting helps. Will have to drill out my plates and weld in some washers once I I find the sweet spot I suppose
My 80 had close to zero castor before I reduced it's lift. Now it's running just over 4 degrees. The factory spec for pre-8/92 is under +2 degree while 8/92 up the factory spec is +3 degrees.
The most critical thing with an 80 would be the toe setting.
And good quality/condition bushes in the radius arms and panhards.
How are you increasing a degree? New plates? IC I see dobinson makes a 5 degree plate. I guess it just depends where you are starting from.
