Hello all,
The knuckles went back together fairly easy, however I re-read the manual and it says to torque the 14mm bolts that attacch the spindle to the knuckle at 15 ft-lbs, does this sound right? doesn't seem like it very tight.
Also, the rotor doesn't spin as easy as I would have thought. The large nut is not tight at all (tightened and then backed off a bit) is it possible to have to much grease in there which would cause the rotor not to 'free spin'.
Any help or suggestions would be greatly appreciated.
Greg
Greg
