Steering Stablizer questions...
Prescott Valley, AZ
Steering Stablizer questions...Power steering?
Today I noticed that my steering stablizer and (I believe its called the) Pitman arm were wet. I wiped my finger across both and it was like gear oil or shock oil or something.
The stablizer itself was wet on the steering arm side...and the part that slides in to the cover when it compresses was covered in like sludgey grease.
I did notice something when I was making a U-turn today that I never felt before. I didn't touch the curb at all but about 3/4 the way through the U turn (left) it felt for 1 second as if I couldn't steer....like if I just put the tires against a wall and couldn't turn....and just as fast as I felt it...it went away and steering was normal.
This is the stock (probably original) steering stabilizer on with a J spring lift.
Does it sound like the stabilizer blew out? :confused:
Would it leak this thing oil (spray it out rather) if it blew? :confused:
I'll try to get pics in a bit...
Well these are the best pics I can take in the dark....
I wiped it all down earlier trying to narrow down where this "leak" could be coming from.
From looking down into the engine bay, everything is dry. There's no spray anywhere in there.
In this pic, the outer cover of the stabilizer is dry...the inner part is still glossy from the liquid. You can see a drip where the liquid has accumulated near that drainhole on the frame.
Looking into the wheel well, I noticed what looks like drip/run lines on the frame.
In this last pic, I pulled up the plasticky shield and I'm assuming thats the power steering pump Im looking at...but I don't see where anything could be leaking from.
I checked the PS reservoir and it is full...
Looking now at the last pic, I see a drip on the end of that pump... I'm starting to wonder now if the pump is developing a slow leak, but not sure where to look on it for the source of the leak.
I will have to check tomorrow when I have more light. If the leak is the High Pressure Line connection...would that just require replacing the hose...or is that an O ring that needs replacing or what?
Line I believe...that is a high dollar part from CDan as I recall...upwards of three digits.
x3 on the line.
Usually you can follow the fluid from a leak up untill you find things dry then you are most often in the vicinity of the leak. 2 cents
I crawled under there again today. Both of the fittings on top (I assume these are both the high pressure and low pressure connections?) - they're both dry including the hoses.
The only part that felt damp is this section shown pictured - would that indicate a worn seal or something inside?
The picture is from under the truck looking at the bottom of the back of the PS pump...
I just got my steering box seal kit today.
I have been leaking where the steering shaft goes into the gear box. I got it from Dan for about 110-120. I am going to rebuild the hole thing b/c the new unit is pretty high ~ 300 seems correct. It looks similar to my problem, mine occured at 175,000 miles.
Hope this helps,
Mark
It could also be the hose between the steering box outlet and the cooler inlet.
In any event it is a power steering leak, not the steering shock.
Mine had a very similar leak and I replace the o-ring where the line attaches. I did it as starting point instead of assuming the line was bad. I still have some seeping because over time I see fluid on the outside of the pump but it no longer drips on the garage floor. I will change out the line only if it gets worse. Might consider that as a cheap starting point.
That last picture you posted shows the steering box not the pump. The steering pump is mounted to the upper drivers front of the motor run with the pulley. ;)
TCH2FLY has a great idea, also you could just check all the fittings in and around there as one could have worked loose. With the high pressure lines it wouldn't have to be very loose to loose a good bit of fluid. If all connections are dry and tight I would say you lost the steering shaft seal where it enters the steering box (the part of the box you have pictured last) or perhaps the sector shaft seal and it is getting blown back as you drive. If it is the sector shaft seal the pitman arm will be all wet too. After looking at the pictures in your first post again I think it may be the steering shaft/steering box junction seal. The box is angled a bit and that is the high point.
I would reccomend spraying that whole area down with a de-greaser and hosing it all off so it is clean and dry. Then take the truck for a short drive or just start it and turn the wheels back and forth a few times then get under and look around, that should help you isolate teh source of your leak. When it is that wet over so many things it can be hard to pinpoint. Good luck and post up what you find.
