Steering stabilizer w/ PS?
I don't run one, might be a little easier on the box if you run one but I haven't found it necessary in terms of handling or road feedback at the wheel.
Hay - thats what I thought. I just want to be sure before I cut the OEM stabilizer mount off the crossmember.
Poser - I am going FJ-60/62 gear box, Sag pump on JT bracket in smog pump location, 4x4 labs high steer. This is on the (in progress) SOA with stock shackles and springs. Cut and turned, or it will be when I work up the nerve to cut my axle :eek:
Sounds good.
Please post up info when you are mounting the steering gear and other goodies, as many people have asked about 60 series steering gear swaps.
:beer:
http://www.marlincrawler.com/steering.html
for ideas
I'm sure it can't hurt - sharp jolts to the steering box aren't necessarily good and I'm not familiar with the 60 series PS gear, mine is a Saginaw and i figured that i didn't need $100 worth of stabilizer for my $15 junkyard box.
I'd probably ditch the stock frame mount (but it's another PITA rivet to deal with) since you're going 4x4labs hysteer and it won't really work with that crossover setup
I did Saginaw Power Steering and haven't run a steering stabilizer since.
I haven't needed one either.
YMMV
Anybody want a good used OME steering stabilizer for an FJ40?
I would be willing to trade for a good 4Runner OME steering stabilizer...
