Hi,
See the picture of my steering-set-up;
1. NEW joints when 1 needs replacement i replace all, steering RODS are solid not PIPES, I made spare tread-bushings left/right treads for later replacements.
2. Steering Damper, the clamping system did not work good for me, this simple system works perfect for my car, only 1 clamp on the steering ROD.
3. Ran a small SS chain so when i do jumps the shaft will never pop-out "again" and the sound is super cool.... works great.
4. Shackle Hanger is on the back not on the front, this makes the car more stable.
5. Shackle hanger rubbers are NOT from PE or PU as they wear-out to easily, i bought some real tough rubber ones with "matting" inside them, they last longer.
6. Shackles are heavy duty, just put them on a few months ago, they seem all right until now.
7. Always when you take off your tires then wiggle your HUBS so you know if you have to tighten up your bearings-nut
8. Every 6 months i pump grease into the BIRD-FIELD joint with a special made grease-nipple
Hope this helped,
Steering set-up is extremely important, some cars have super expensive set-ups other cars simple like mine, but IT HAS TO WORK PERFECT.
Andre
