Yes, however, there are several versions of the saginaw box. Some of the differences are:
1. Piston size (Cast # 5691676 is a small piston, Cast #5687962 is a large piston)
2. Ratio. Basically, there is a 3 turn box and a 4+ turn box. Most like the 4+ turn box however, my experience is that they are a bit harder to find.
3. Input spline size. (I know there is a 3/4"x36 spline and a 13/16"x36 spline. I've generally seen the larger 13/16"x36 spline.
All bolt patterns are the same but there is a 3 bolt box and a 4 bolt box. I think most everyone will recommend using the 4 bolt box and 4 bolts to hold it in place. Also, I recently learned that the large piston box has a larger body and requires a bit more space between it and the mounts. Depending on the mount you use, this may or may not be an issue to deal with.
For reference, AGR uses only the large piston box. And their Land Cruiser boxes are the 4+ turn box.
