Steering box gap
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
I know these LCs have an inch or so of play in them, my steering wheel has a nice 1in or so of dead space, but I installed a new (remanned rock auto) steering gear and a new pump a while back, But it has a a lot of play and shes got a nice pre warmed up whine. anything I can do? or is it just what it is.
You can try adjusting the bolt on the top of the box. Best to do that with everything disconnected so that you can feel the excess drag when you get it too tight. Otherwise the play would be from endplay on the input shaft, which I believe is only adjustable by shims.
Have a helper rock the steering wheel while you touch each of the tie rod ends to see if any of them are worn/loose. Bad track bar bushings could also allow excessive steering play. If not there, then jack up the front axle and check wheel bearing play by rocking tires in and out with yur hands at 12 & 6 oclock.
TREs are new and I tried this already, so Im looking at maybe adjusting bolt on top of box. Im wondering why its starting to whine old OEM was quiet after I bled it out correctly
Contact @landtank he knows the internal part that needs replaced to bring it back to new.
its remanned just installed a few months ago from rock. I have 2 spare boxes I may rebuild and swap in. NG on LT
All rebuilders only replace bad parts out of 'tolerance':rolleyes:
IIRC in the past LT has said 'this' $$ part must be replaced if you want a tight box like new.
  • Like
Reactions: RFB
Whining would be from the pump cavitating and/or being under a lot of load. I dunno about the petrol motors but with the diesels the ps pump is a gear-driven sliding-vane type pump and when they wear they can cavitate. Also check all of the hose/pipe connections to make sure you're not losing fluid as low fluid level can cause the pump to drag air in which adds to cavitation issues.
  • Like
Reactions: RFB
this is a bolt that goes thru block that wont tighten properly and def leaks. I want to replace this bolt but dont know whats its called and if all LCs have it,or was it a "fix"
B= the pass thru bolt that the power steering pump attaches to, one of the two
and
A=another nut on opposite side of block hope it makes sense
B
Double hex head stud lobular.
If its the one bolt, actually a stud, I think it is... it's called that or something close to that. Like $16 bucks.
Threads into the block and has a nut on either end. Different size on either end too. Actually bought one of those once but don't know the part number off hand.
  • Like
Reactions: RFB
@RFB did you replace the high pressure hose as well?
For the play, adjust the nut on the steering box as others have suggested but only turn it a 1/4 turn at a time. The FSM calls for 40mm of play. Put a strip of painters tape on the steering wheel and a ruler on the dash to roughly determine free play.
  • Like
Reactions: RFB
One thing to keep in mind is that the steering in an 80 will *never* be as 'tight' as on a vehicle with rack-and-pinion steering, but there are ways to make sure as much of the 'freedom' as possible is out.
Did an complete internal rebuild on mine and it's worth it.
Parts are around $600.
Labor, varies.
thats what Im doing I have 2 extra steering bxes
I spent $30 on a steering box rebuild kit and $100-something on a reman PS pump. Fluid cost $50 because I bought three gallons.
Ive replaced all my steering hose hi and low and all mechanical
