steering box-----'78
Decatur, Ga
I checked the archives and did not see where this question was asked.
I checked steering box for the first time since we have had the FJ for the past month. (It spent 3 years in a barn in Missouri prior to us) It was empty. I stuck a narrow rod in there to even see if anything was even moist.
Nope, nuttin.
So I filled it up with 80/90. Fine. I feel better.
Ok, I have now discovered that it leaks, as there is a nice puddle of clean 80/90 on the driveway, directly under the steering box.
I have checked SOR and it looks like there is only one place where it could leak from? Driver-side lower, where the tightening bolt is. They sell a gasket for it, and did not see any other gaskets for sale, so I am assuming that is the only seal that it could be leaking from.
Is this correct or there other places where it could be leaking from?
Thanks.
They normally leak from the sector shaft seal. The sector shaft is where the pitman arm attaches with the large nut. Often the seal leaks because the sector shaft bushings are worn out. Have someone rock the wteering wheel back and forth while you watch the end of the sector shaft. If it wobbles back and forth as opposed to rotating, then the bushings are bad and will need to be replaced and honed to size by a machine shop first, or the new seal will likely leak.
Changing the seal is a job because you need to remove the pitman arm. Buy or rent the beefiest puller you can find. Tighten the puller than whack the side of the pitman arm with a hammer and repeat until the arm pops off.
PabloCruise said:
I am betting it is the sector shaft seal...
Yep, that is what SORs cateloge says. Can it leak anywhere else from the steering box?
Puller? Strong/Large Gear puller work or is there some other sort of puller that I should look for?
Thanks
Thanks
The ONLY puller I have ever had any luck with is the Snap-On unit.
Broken several others, including the teeth off a 7-ton gear puller.
Took several minutes of working the snap-on puller with an impact wrench to get it off.
Aluminum will not cut it- you need a fullsize cup-style (not claw) puller made of steel.
Whack it smartly on the big end of the pitman arm right over where it engages the splines on the sector shaft. Don't hit the pitman puller and put a towel over it so it won't hit you in the head if it comes off. Penetrating oil and heat may help.
Heat and a BFH got mine off after I broke 2 pullers...Made a puller from the remains of the first two and then heated it up and whacked it with the hammer... sounded like a gun going off when it popped. The heat might hurt the sector seal but your replacing it anyway.
Kevin
