Starter Rebuild... Fail
Why not a reman starter? I had the same problem and just got a reman, getting that ip thing in and out of the truck wasn't easy and you already did it more than once.
Just an FYI, in June I had 2 OEM remanufactured starters that were bad out of the box. Both had contacts that were incorrectly installed and one had an old plunger that someone put on wire wheel to "clean up". Both had a layer of crap inside the solenoid cylinder.
After cleaning them up and adding a thin layer of lightweight lube, straightening the contacts and replacing the used plunger with a new one, both are working without issue.
It is also worth it to take the time and clean up the positive battery ring terminal that mates to the solenoid with a bit of emery paper.
Hijack:
I've been having some cold start issues too where it sounds like the "starter" will "stop" for a split second before "engaging" and starting the truck. Happens if it's chilly out - last winter it was below 50* - this time I got it to happen when it hit probably under 60*. I have a video of it from last year but never got it into a shop for diagnostics. This time, it's going in if you guys don't think it's the starter.
Bad contacts; either the solenoid contacts or the brushes..
In theory I did both the " right " way .. curious every single time I test it on the bench works flawless ..
Has an aftermarket alarm system ever been installed on it? I had the same issues and did the plunger and contacts which needed to be changed and then the problem happened again. just clicking. then it would start. turned out one of the 2 wires that plugged into the aftermarket alarm for the starting circuit had come loose. acted just like a bad starter. click but then nothing. Might not be anywhere near the ballpark with this but I'm sure my rig isn't the only one with a cheesy aftermarket alarm added somewhere along the way.
